TDrive is on work in progress Ibus application. The program is on early coding stage. It is going to be modular structure, user/developer will be able to enable desired modules. Software is licenced under GNU General Public License 3.
Planned modules: Ibus debugger
Ibus receiver
Ibus sender
CD Changer emulator
Radio screen text sender
Bluetooth A2DP & Handsfree
Vehicle Controller over Bluetooth
5V power supply
Late stage features in case of using Arduino DUE
Vehicle tracker&logger over GPRS (very late stage, is CANBUS necessary?)
MP3 Player and Ipod Interface (maybe on very late stage, not sure if it is necessary when you have BT Streaming)
Components
1×
Arduino
Arduino Nano, Mega or DUE depending of required modules.
Code is available on GitHUB, it is probably not usable yet. I am not coding it on the bench. When I feel that it is ready for debugging, I am going to start to give last shape on the bench.
