Here are a few pictures of how I use this robotic component:
Here you see a two axis gimbal to move my camera. With a angular resolution of 0.03 degree, it should be possible to use this setup to compensate for earth rotation while doing astronomy photography.
The two strain wave gears are connected by a big, bone like part, that was topology optimized in fusion 360 and glued together after printing it in four parts. The parts have holes for pins to align them properly.
Johannes Hassler
