The Gear in Action
A project log for 3D Printed Strain Wave Gear
printed - using only PETg, no flex filament needed integrated NEMA17 stepper motor only three small parts for tolerance compensation
johannes-hasslerJohannes Hassler 04/25/2018 at 22:330 Comments
Here are a few pictures of how I use this robotic component:
Here you see a two axis gimbal to move my camera. With a angular resolution of 0.03 degree, it should be possible to use this setup to compensate for earth rotation while doing astronomy photography.
The two strain wave gears are connected by a big, bone like part, that was topology optimized in fusion 360 and glued together after printing it in four parts. The parts have holes for pins to align them properly.
