Thirsty Plants
Monitor the health of my plants using an Arduino. Water them with code!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I have a couple of condiment plants that haven't been doing very well so I'm throwing Arduinos at the problem. The initial plan was to just monitor the plants and set a reminder whenever they need water however I'm going a step further and making a semi-automatic watering system using a peristaltic pump controlled by an Arduino. I'm also going to split the output pipe into 3, probably using a 3D printed adapter with a solenoid on each end, to meet the needs of the plants individually.
