Not enough power
A project log for Ultrasonic Parking Aid without Arduino
Low power, battery operated ultrasonic parking aid.
jscjsc 06/26/2014 at 18:410 Comments
Driving the HC-SR04 from a digital pin doesn't work. From a thread on avrfreaks, it appears it can draw up to 100 mA peak power, which is more than a digital pin can provide. Soldering a large cap across the VCC and GND pins lets it work when powered continuously, but causes it to return nonsense values when trying to turn it on and off. Need to put in a transistor as a switch.
