Power failure
A project log for Weather & plant monitoring station
Arduino controlled wifi weather station, with local database, dashboard and online controllable watering system.
detoDeto 06/16/2016 at 22:110 Comments
Cheap ass chinese LM2596 power supply failing after running for a long time.
As you can see on the image above, the measured voltage went up because the supplyied voltage changed from 3.3V on the Pro Mini.
