THE PRICE OF THIS PROJECTOR IS DIY WHICH YOU CAN ATTACH TO EACH PAGE OF THE BOOK AND EVERY BOOK EVER CREATED WILL WORK WITH THIS
View all 6 components
USE SCISSORS TO CUT A CIRCLE OUTSIDE SHOEBOX THEN PUT LENSES N CIRCLE AND THE PUT YOUR PHONE IN SHOEBOX THEN PROJECT A EBOOK TO BLANK PAPERBACK BOOK
View all instructions
I'd suggest removing the all-caps from the description in the title.
Remove your house address from your user profile.
Edit your title and description so they agree.
Consider using e-ink instead of a blank book and (two?) projector(s) to decrease cost and weight.
Does this work on... Pop-up books?
Toby Bateson
mulqimffd11
roachish
gavas_ymail
Yes, delete it Cancel
You are about to report the project "projector that projects on paperback books", please tell us the reason.
