Automated Bartender
An Arduino/Raspberry Pi powered bartender that mixes drinks for you.
We entered the Hackaday Automation Challenge!
Our goal is to automate domestic bartending. The problems we are tying to solve are spilled beverages, poorly mixed drinks, and mixing speed at a social gathering. The automated bartender is not meant to replace human bartenders; rather, it is designed to enhance the mixology experience.
We've built an Arduino + Raspberry Pi powered robotic bartender before, but it mixed drinks too slow to be practical. We want to build a new version which is faster, more accurate, and can mix more than one drink at a time. In this series, we plan to show you how to build all the components so that you can make your own.
This is an ongoing project. We will share video links every other Thursday when we post them on our channel. Materials lists and links to code will be posted here when available. If you have any suggestions or feedback -- please let us know!
Here's a running list of our video parts:
Part 1: https://youtu.be/x6QYNK6WI50 (Planning and Design)
Part 2: https://youtu.be/orMLuXoaTSQ (Platform and Modeling)
Part 3: https://youtu.be/IKZFf-zl0Bo (Frame and 3d Printed Parts)
Part 4: https://youtu.be/aAgKmiabQy0 (Varnish and Flow Meters)
Part 5: https://youtu.be/SXW7ydvqfnM (Shift Registers and Initial Wiring)
Part 6: https://youtu.be/-UzgQpltkWM (Drive Motor and Cupholders)
Part 7: Coming soon
motor_drve_wheel.stl
Standard Tesselated Geometry - 957.50 kB - 10/02/2016 at 19:01
Download
cupholder_base.stl
Standard Tesselated Geometry - 478.21 kB - 10/02/2016 at 19:01
Download
motor_mount.stl
Standard Tesselated Geometry - 495.49 kB - 10/02/2016 at 19:01
Download
motor_stand_reva.stl
Standard Tesselated Geometry - 752.62 kB - 10/02/2016 at 19:01
Download
arm_c.stl
Standard Tesselated Geometry - 420.79 kB - 10/02/2016 at 19:01
Download
View all 10 files
View all 25 components
  • Part 6: Drive Motor and Cupholders
    Hacker House10/02/2016 at 19:22 0 comments
    In part 6, we mainly focused on 3d printing some components for the drive motor and cupholder mechanisms.
    We recently purchased a relatively high torque motor on Amazon that we will use to drive the drink platform. The idea is that this motor will be mounted underneath the platform and spin it via a grippy wheel. In order to raise the motor so that our grippy wheel touches the bottom of the platform, we created an elevated motor mount.
    We also created a mechanism to hold our cups on the platform while it is spinning. We created some holder arms with torsional springs to prevent cups from moving around and accommodate several different sizes.
  • Part 5: Shift Registers and Initial Wring
    Hacker House08/20/2016 at 15:04 0 comments
    Part 5:
    Our Arduino needs to control several components (actuators, pumps, drive motor, position switch) in order for the bartender to work, but there aren't enough pins on the board to individually control each of these components. We decided that shift registers would probably be the best way to control multiple outputs with only a couple of pins on the Arduino. I spent some time explaining how shift registers work and where they would fit into our schematic.
    I also laid out all of my electronics and used the whiteboard to draw a mock diagram of how the components interface with each other.
    I wrote a sample Arduino program that tested the shift registers and began wiring the components together. These components were then tested with the linear actuators on the bartender.
    Finally, Davis modeled and printed some more parts for the linear actuators that sit on the corner of the support post. They extend a bit further out than the other actuator brackets, so we also printed a some smaller extension pieces for the dispenser lever.
  • Part 4: Varnish and Flow Meters
    Hacker House07/29/2016 at 15:17 0 comments
    Here's the 4th part in our series:
    In this video, we varnish the frame and put a coat of polyurethane to protect the wood from any spillage that may happen while the bartender is mixing drinks.
    We also bought some flow meters to make our mixer output system more accurate. I setup an experiment to verify that our flow meter works as expected.
    Davis starts using a new modeling software called Creo PTC. This program can speed up modeling because subcomponents are built on a parameter tree. A change to a parameter in the tree can effect everything dependent on it . In 123d, it is much more difficult to make changes once a part is built.
    Using this software, he created some mounting brackets for the mixer pumps. Davis also assembled 4 of the 6 dispenser mechanisms with a few parts that we printed since the last video.
  • Part 3: Frame and 3D Printed Parts
    Hacker House07/16/2016 at 18:31 0 comments
    Here's the 3rd part of our robotic bartender project.
    In this video, constructed the fame for our bartender. We also got a chance to use the 3d printer to make some components for the spirit dispensers and actuators. The dispenser lever was redesigned to remove the curve so that the force from the actuator was more constant. A bracket was also made to hold the actuator on the main post.
    These are some images of the mechanism being tested.
    Lastly, we tested some self priming pumps to be used for dispensing mixers. We found some cheap one on amazon for about $10.00. A flow meter will be attached to measure the amount of fluid poured into the glass.
  • Part 2: Platform and Modeling
    Hacker House07/16/2016 at 17:36 0 comments
    Here's the 2nd video for our robotic bartender project.
    In this part we deconstructed the old bartender to reuse some parts for our new project. We also spent some time building the rotating platform. This will be used to move the drink glasses whilst the barbot is operating.
    We also built a 'CAD' model to visualize, manipulate, and verify our design. We decided that the actuators will be positioned on the main center post. The dispenser levers will be inverted so that our actuator arm will have a track to slide in. In order to verify that this will work, we built a test stand and used a power supply to actuate the arm.
  • Part 1: Planning and Design
    Hacker House07/16/2016 at 17:16 0 comments
    Here's an update for the 1st part of the project:
    We've built an Arduino + Raspberry Pi powered robotic bartender before, but it mixed drinks too slow to be practical. We want to build a new version which is faster, more accurate, and can mix more than one drink at a time. In this series, we plan to show you how to build all the components so that you can make your own. Here's a video of the old one:
    In this video, we discuss some features on the old bartender and whiteboard a new design. Our new design will be circular so that it can mix drinks concurrently. The design will also allow the platform to spin faster. Here's a quick whiteboard drawing of what we were thinking.
View all 6 project logs
geoimpexllc wrote 12/15/2022 at 06:45 point
You really did a great job to make this program object i want to embed it with my webpage can you see here https://vinylflooringsale.com/
Sai Ganesh wrote 09/07/2017 at 15:31 point
Hi, i am working on a same kinda a project , just wanted to find out more about the universal car door lock actuators,
i am planning to use the regular shot dispensing (found cheap on eBay for a pack of 6)
just wanted to know if the torque from the door lock actuator is enough to push the dispensing lever all the way , i wanted to be mounted just below the nozzle and some linear motion to push the nozzle up for pouring
ricekrispies.browne wrote 03/03/2017 at 03:32 point
hey guys just wondering when you will be doing the raspberry pi video?
