Transducer CAD model
A project log for Zymeter
A device to monitor the progress of fermentation (pH, specific gravity, alcohol, temperature)
anfractuosityanfractuosity 06/15/2014 at 13:260 Comments
I'm currently working on creating a 3D model of the transducer and chamber in FreeCAD, based on the transducer's 2D CAD drawing, I obtained from the manufacturer.
The transducer has a 2mm thick flange, which I'm thinking of either clamping to the chamber, or making use of some form of adhesive.  Ideally clamping would be best, for long term usage I think.
