Remote Control and Sensor eCog Snap Packs up for Pre-Order.
11/04/2016 at 20:34 • 0 commentsIf you have an idea for an IoT project that uses Remote Control IR commands or Sensor data then these eCog Snap Packs might be right up your alley.
The Sensor eCog Snap Pack pairs with the Arduino Mini Pro (Clone) GadgetBox and lets you connect any of the sensors from the popular 37-in-1 Sensor Kits to make a nice looking Sensor based IoT device. Starting at $11 for the GadgetBox and $10 for the Sensor Snap Pack for a total of $21 is a heck of a deal for an enclosure, battery charger, esp8266 wifi, and sensor eCog.
The Remote Control eCog Snap Pack pairs with the Arduino Mini Pro (Clone) GadgetBox to give you full IoT control over your Remote Control devices. Learn IR commands and blast them back out with the dual IR transmitter and make your IR devices controllable with web services, phone apps, or Home Automation controllers. Starting at $15 for the Remote Control Snap pack and $11 for the Gadgetbox for a total of $26 for an IR gateway.
We are taking pre-orders now and hope to have everything shipping by the end of November. Be the first to check out the GadgetBox hardware and let us know if this is an idea that is worth pursuing. We are doing a limited run of 50-100 of these devices to see if there is enough interest to continue developing more eCogs and GadgetBox options. We need your help to get this idea off the ground...
If there is enough interest we will proceed with the following GadgeBoxes that we are currently testing:
- Teensy 3.2 and LC
- NodeMCU
- Raspberry Pi
- ESP32 (If we can get our hands on one!)
- GR8 C.H.I.P Pro (waiting for one to arrive still)
To see all of the GadgetBox, Snap Pack, and eCogs options visit GadgetFactory.
Thank you for checking out this GadgetBox idea, we appreciate all help and feedback.
Jack.
Taking Pre-Orders for the first batch of GadgetBoxes!
11/02/2016 at 16:04 • 0 commentsBe the first to try out the GadgetBox! We are just waiting for some charging modules to arrive from China and then we will have everything ready to go with the first batch of 50-100 GadgetBoxes for the Arduino Mini Pro. We finished the hardware guide, made the product page, and even got the GadgetBox library accepted in the Arduino IDE library manager. Everything is ready to go, so we decided to start taking pre-orders now and as soon as we get the last shipment from China we will ship the very first GadgetBoxes out.
You can get one of the first GadgetBoxes for as low as $11 for the unsoldered option. For $11 you get an enclosure, battery charging module, and the GadgetBox Motherboard that breaks all of the IO of the Arduino Mini Pro (clone) into four easy to interface locations. Perfect if you have a project in mind and can forgo the eCogs for now and just directly solder your components to the Motherboard.
Up next for documentation and pre-orders is the following eCog Snap Packs:
- A sensor Snap Pack - Takes any sensor from the 37-in-1 Sensor kits, an ESP8266 Wifi Module, and an I2C OLED display module.
- A remote control Snap Pack - eCog to send and receive IR commands, ESP8266 Wifi Module, and an I2C OLED display module.
- Barcode Scanner Snap Pack - PS/2 connector for a barcode scanner, EP8266 Wifi Module, and an I2C OLED display module. (This was a special request to make an Iot Barcode Scanner)
We would love to hear your ideas for eCog Snap Packs, please feel free to comment with your ideas.
GadgetBox UserGuide for Arduino Mini Pro (clone)
11/01/2016 at 18:10 • 0 commentsOk, the UserGuide for the first GadgetBox which uses an Arduino Mini Pro (clone) module has just been completed and posted online:
Up next is the User Guides for eCogs, eCog Snap packs and then the following GadgetBoxes:
- Teensy 3.2 and Teensy LC
- NodeMCU
- Raspberry Pi Zero
First GadgetBox test run almost ready!
10/31/2016 at 16:40 • 0 commentsHello everyone,
Exciting news, I'm just about finished pulling everything together for the first test run of 50-100 GadgetBoxes for the Arduino Mini Pro (clone) modules. One of the biggest problems was getting the price right and by using existing modules I think I have finally found the right approach. The pricing will be very affordable (it's not much more then you would pay for just an enclosure!):
- $11 for the GadgetBox enclosure, motherboard, battery charging, and supporting hardware. This is not soldered so you can decide how to configure it. Maybe you don't want to use eCogs but instead want to solder your own components directly to the motherboard. You bring your own Arduino Mini Pro module
- $15 for the GadgetBox enclosure, motherboard, battery charging, and supporting hardware - with this option the motherboard is already soldered. You bring your own Arduino Mini Pro module
- $16 for the GadgetBox enclosure, motherboard, battery charging, Mini Pro Module (clone) and supporting hardware - Not soldered.
- $20 for the GadgetBox enclosure, motherboard, battery charging, Mini Pro Module (clone) and supporting hardware - Motherboard soldered.
I just received the first 100 enclosures with the cutouts and silkscreen for the Arduino Gadgetbox. Here's a look at them in the box:
I've also got about half of the components needed for a first test run of 50-100 Arduino Mini Pro (clone) GadgetBoxes. Just waiting for the Arduino Mini clones now, here is what it looks like without them:
I'm also finishing up the hardware guide which I hope to have done today or tomorrow and will post about here.
Keep watching if you want to be one of the first 50-100 to test out the GadgetBox. :) -
GadgetBox - eCog Snap Packs
09/13/2016 at 22:01 • 0 commentsSnap Packs are 4 eCogs manufactured together as a single board that can snap apart into individual eCogs.
This saves on manufacturing costs!
Assembling GadgetBox IOT Enclosure
09/13/2016 at 21:56 • 0 commentsShows how all the pieces of the GadgetBox go together:
* The Enclosure
* The optional battery
* The GadgetBox Circuit Board
* The Universal eCog Modules
GadgetBox 2.0 Redesign - Enabling Universal eCog Modules
09/13/2016 at 21:24 • 0 commentsWith the first GadgetBox design I realized that I painted myself into a corner by putting the headers in the middle of the board. Doing so limits the different IOT modules that we can put into the GadgetBox.
One of the goals with GadgetBox is to make eCogs a Universal plugin that can be used no matter what IOT platform you are using. Whether that be Arduino, Teensy, Raspberry Pi, ESP8266 and so on. If you have a SD Card eCog there is no reason you shouldn't be able to use it with any of the above mentioned modules.
By redesigning the GadgetBox to make more room for larger modules such as the Rasberry Pi Zero we are that much closer to Universal eCog Modules all housed in an attractive enclosure.
Keep tuned for more information as the GadgetBox development continues.
First GadgetBox project: Remote Control.
08/06/2016 at 17:17 • 0 commentsHere is a quick video showing the first working GadgetBox using a pCog (project Cog) design to implement a working remote control solution. A pCog is four eCogs that are manufactured together and can be snapped into four separate eCogs if desired. For example the eCog in the upper left quadrant of the pCog is a blank eCog, if we wanted to add a display instead we would just snap the pCog apart and replace the blank portion with a display eCog.
pCog Circuit Boards arrived.
07/29/2016 at 19:30 • 0 commentsI just got back from vacation and found some circuit boards waiting for me!
Here are some pictures of the pCogs in different colors so we can get a feel for how the contrasting colors look with the boxes.
My vote is for the Black case and Red eCogs, allthough the White case with Red eCog looks good too.
Bluetooth (BLE) HM-10 eCog
07/12/2016 at 18:22 • 0 commentsJust made a Bluetooth (BLE) module using the HM-10 module:
Jack Gassett
