Hi! Again on same project that I have established before on Dell 2408WFP and within reach of great NEC 2090UXi which I have modified it to RGB-LED Backlit.
As I learned so much during these projects and as colourist willing to make best possible display for grading (even though you have to buy expensive display for critical work).
The model I owned is A1038 which is 20 inches 16:10 Apple Cinema Display with resolution of 1680X1050.
The critical part of getting great color out of this modification will be the LED itself. You have to use
- Red Primary at 625nm
- Green Primary at 528nm
- Blue Primary at 467nm
<a href="http://www.aliexpress.com/item/1000-pcs-RGB-PLCC-6-5050-3-CHIPS-SMT-SMD-LED-Chip-Lamp-Beads/32383389763.html?spm=2114.13010608.0.60.ECoaSP" target="_blank">http://www.aliexpress.com/item/1000-pcs-RGB-PLCC-6-5050-3-CHIPS-SMT-SMD-LED-Chip-Lamp-Beads/32383389763.html?spm=2114.13010608.0.60.ECoaSP</a>
The Project will begin soon.
Hey there. Did you end up modifying your cinema display? I have a 23" DVI one with faded CCFLs and I am trying to work out a strategy for modifying its backlight. I also have an i1 Display instrument and Arduino working knowledge so yes, very interested in any info you might have to share.
