Hi
For two years I started the project "Pokemon Go Plus DIY" in hackaday.io, today thanks to Yohanes Nugroho at TinyHack it has been possible to discover a way to create a DIY version.
Because the encryption keys for each device are unique as Yohanes Nugroho explains in his post, Today I open a campaign to raise money and buy a Pokemon Go Plus device to extract the keys from that device and publish it in an open firmware for the ESP32 microcontroller.
I only need $80 dollars to buy the device, I have the tools and knowledge to extract the firmware.
If you want to support me, I promise to deliver:
- Code for ESP32 with keys working.
- Firmware extracted for further studies by third parties
WARNING:
- All devices that have this firmware will have the same MAC and keys, there is a risk that Nintendo will block the accounts that use this device.
I will start the process as soon as I get the money to buy the device and I will publish all the updates in https://hackaday.io/project/12680-pokemon-go-plus-diy
If you want to donate from 3 dollars you can do it in the following link
