Coming together....
A project log for ramanPi - Raman Spectrometer
The open source 3D Printable Raman Spectrometer using a RaspberryPi and easy to find off the shelf components..
flcfl@C@ 07/13/2014 at 00:322 Comments
Here's the latest shot of the case with the electronics and some of the optics mounted nicely inside... (Nice cable routing will happen later..)
From the front.... The LCD is stuck on with double sided tape for now..
The inside...  It's starting to take shape..!
zakqwy wrote 07/13/2014 at 01:30 point
Wow, the chassis looks great! I'm a fan of the handles!
fl@C@ wrote 08/03/2014 at 07:55 point
Hey Zach! Sorry for the delayed reply! I didn't realize there were comments on the posts! And apparently the site doesn't notify you!!
Thank you! I love this case... It's a miniITX case called Prodigy by BitFenix.. Amazon has a ton of different versions and colors... Fairly cheap.. I'm doing everything I can to fit everything into it without modifying anything that'd make it hard for people to do at home.. I agree, the handles give it a cool touch..
I've made a lot of progress since these were posted too btw... I'll be posting some more stuff (and actually did a little bit with the LED ring) soon... I have the TFT mounted and the LED ring functional finally.. :)
