Arduino Yún Controller
The Yún Controller app allows you to control the digital pins and monitor the analog pins of your Arduino Yún board wirelessly.
App to control an Arduino Yún board.
I should add that I'm not a proper developer, but an amateur. This is my very first app for iOS. I will keep improving this app as long as I learn more about programing :)
  • New big update
    AllMyCircuits.io09/15/2014 at 09:32 0 comments
    The app has been updated with a new design. I have used a different method to communicate with the Yún board. Also there are less bugs and more control of errors.. Check it out and tell me how I can improve it.
View project log
ryansmith715 wrote 04/24/2015 at 14:34 point
Do Arduino UNO R3 have WiFi capability or would i need to add that in before i buy your app! Great job man!
AllMyCircuits.io wrote 04/24/2015 at 14:49 point
Hello and thanks for your words. This app is only for the Arduino Yun board, so you can't use it with Arduino Uno. But I made another app called Etherino which works with Arduino Uno with Ethernet shield. If you needed more info don't hesitate to contact me again and I will help you ;)
