LT3514power is a triple-output switching DCDC converter, based on the LT3514 IC from Linear Technology.
Input voltage can reach up to 36V, the lower bound is determined by the desired output voltages. Such voltages can be set through feedback resistive networks.
PCB files (designed with Kicad) and Gerber files are available on Github, along with an Octave file (calc.m) to determine component values.
Black PCBs from Elecrow.
Hello,
Is the BOM open for download ?
