Real thermometers has ethernet
90% copy paste mocked up code from Arduino examples. And a small custom shield for the DS18S20 and 1602 LCD.
This replaces my China Temper USB (Laboratory, LOL) indoor thermometer that was running using questionable third party software from sourceforge to upload measurements to my webserver which is programmed as a "brain" for my home automation system. I'm using an RFXcom usb tranceiver to talk to my EMW100R switches running both lighting and heating in my rented house. Software may get some updates.
STORJtokenbalance1602LCD.ino
Mashup code to only display STORJ token balance using tokenbalance.com API
ino - 6.91 kB - 08/11/2019 at 15:32
Download
autohome-tempsensor-http-client -censored.ino
Code
ino - 8.79 kB - 02/08/2018 at 19:57
Download
ah-bottom.stl
Case
Standard Tesselated Geometry - 117.27 kB - 02/08/2018 at 19:52
Download
autohome-therm-case.dwg
Case
DWG Drawing - 161.50 kB - 02/08/2018 at 19:52
Download
ah-top.stl
Case
Standard Tesselated Geometry - 109.46 kB - 02/08/2018 at 19:52
Download
  • 1 × wire Resistors (Fixed) / Zero Ohm Jumpers
  • 1 × 1602 LCD
  • 1 × 3D printed box
  • 1 × Arduino uno
  • 1 × Ethernet shield
View all 8 components
