New Test Engine - Z18XE
A project log for RabbitDueOpenECU
DIY Automotive ECU with ARM Cortex M3 Arduino Due Controller
matthewmatthew 04/18/2017 at 12:310 Comments
This project pretty much hit the limit of what you can do with a simple throttle body injected engine. Basically not a lot!
So time for a new test engine - Z18XE that comes with OEM Siemens 60-2 crank trigger, 1 tooth cam sync, 4 cylinder sequential injection, direct fire coil-on-plug ignition, electronic throttle control and hot-wire AFM.
The Rabbit Due Open ECU was in need of a tricky crank trigger test. The magnetic reluctor 60-2 seemed like a good start. So far so good, with the Rabbit ECU running fuel only batch-fire injection. The Siemens ECU is still running ignition and electronic throttle control.
In the coming weeks I am hoping to test the Rabbit ECU reluctor adapter (VR) circuit a lot more. One nice feature of the circuit is the ability to set the hysteresis thresholds in software depending on engine speed. So good pickup of a weak cranking signal along with high resistance to noise at high RPM when nasty VR cross-talk occurs.
You can see in the last scope the circuit seems pretty robust to noise on the bench at least.
Next step for the Rabbit ECU project is working with the hot-wire AFM. So far the car runs nicely but hooking up an AFR gauge will tell us more...
