Although there are so many RFID reader in the market but in this article i will be using an Arduino RFID Shield from <a href="http://controleverything.com" target="_blank">controleverything.com</a>.
Why this shield
This shield is so much easy to use all you need to do is plug you arduino into it and you are good to go.
The RFID reader comes with a 6 inch cable so you can mount this out side a door or on wall.
What you need to make this project.
1. Arduino RFID Shield
2. Arduino Nano
This RFID kit comes pre assembled so all you will need to do is plug your arduino in it and you will be good to go.
This RFID works on uart protocol so to read the RFID tag we will need to read the uart data.
In this sample code we will read the RFID tag and will display it on the serial monitor.
int count = 0; // count = 0char input[11]; // character array of size 12 voidsetup(){
Serial.begin(9600); // begin serial port with baud rate 9600bps
voidloop(){
if(Serial.available())
count = 0;
while(Serial.available() && count < 12) // Read 12 characters and store them in input array
input[count] = Serial.read();
count++;
delay(5);
Serial.print(input); // Print RFID tag number
Serial.print("\n");
2
Step 2
Using the earlier code we will read the RFID tags we have and then we will save them in a data base and then when the next time user brings his card near the RFID reader we will read and will compare it with the existing database. # Arduino-RFID-Shied
void loop()
count = 0;
{ input[count] = Serial.read();
count++;
delay(5);
Serial.print("\n");
if ( strcmp(input,"0A006FBE33E9") == 0)
Serial.print("Tag One"); Serial.print("\n");
} if ( strcmp(input,"0E004560173D") == 0)
Serial.print("Tag Two");
Serial.print("\n");
if ( strcmp(input,"0A00706AF0E1") == 0)
Serial.print("Tag Three");
Serial.print("\n");
if ( strcmp(input,"28018389B696") == 0)
{ Serial.print("Tag Four");
Serial.print("\n");
3
Step 3
there is a lot which can be done with Arduino and this RFID shield.
1. RFID controlled gate
2. RFID controlled Door lock
3. RFID controlled lights
4. RFID attendance system
There is no soldering required in this kit so this is an ideal kit for schools,kids, software developers and all the people who doesn't want to do soldering.
Is any way to add a sd card slot shield and save all the informations on it ?
