IOT Led Matrix Projector Clock
Inspired by a couple projects, a projector clock based on a modified ikea lamp
An upgraded dual interface IOT clock based on a hacked ikea light inspired by Alain Mauer
I dont like typing long winded writeups so this will be very brief.
The original idea was taken from https://hackaday.io/project/12084/instructions. But making a clock from an 8x8 is challenging due to the lack of real estate.
I evolved the project to use a single ESP based WeMos mini. Also CAD up two parts to interface with the existing hardware and the new LED matrix.
Great thing I am good at copying so I found this project to combine
https://github.com/formatc1702/Micro-Word-Clock/tree/master/v2
But the wife complained that the font was hard to read without glasses so a second mode was added based on this clock:
https://www.flickr.com/photos/funnypolynomial/7762845146/
I also tackled the brightness issue by changing the current limiting resistor on the MAX7219 boards to a 2k resistor yielding a 150mA surge current for 1/8 duty cycle.
The code is hard coded to change to the semi-analog version between 3 and 8
A very crude DST algorithim is added in addition to synchornization to the NTP pool server since I dont have a RTC.
Feel free to modify the code on git hub to add more functionality and perhaps a better web interface.
https://github.com/lalalandrus/Ikea-Projection-Clock
projector_cap.STL
End cap for projector so it can stand on end.
Standard Tesselated Geometry - 23.91 kB - 09/03/2016 at 06:09
Download
projector_adapter.STL
Adapter for LED matrix to existing slide holder
Standard Tesselated Geometry - 1.64 kB - 09/03/2016 at 06:09
Download
  • 1 × MAX7219 Board
  • 1 × WeMos ESP8266 Mini
  • 1 × Ikea Sprida
  • 2 × 3D printed parts
  • 1
    Step 1
    Print 3d parts
  • 2
    Step 2
    Change R1 to 2k on MAX2719 breakout board (or add a 3k resistor in parallel)
  • 3
    Step 3
    Fit LED matrix into printed adapter and in turn adpater into holder holder
View all 7 instructions
EngineerAllen wrote 01/31/2017 at 12:49 • point
more photos of how you put light on ceiling?
