Smartphone based wifi controlled remote door lock
This is a wifi based remote door lock that can be easily controlled via android based smartphone. Includes full duplex voice support
This is a wifi based remote door lock that can be easily controlled via android based smartphone. It works as follows:
1. The person standing outside can press a button to notify that someone standing outside.
2. The connected smartphone gets notification (similar to phone call).
3. Once the notification is acknowledged, a full duplex VOIP channel gets created that is used to have a voice chat with the person outside to have a proper identification of the person.
4. The person inside then can choose to open the door by pressing another button on the android app.
5. If nobody present at home and someone rings the bell, a voice message would be there to inform, and the person can record a message that can be played later once smartphone is connected.
  • 1 × nodemcu Wifi MCU - ESP12E variant
  • 1 × Arduino uno used as ADC and DAC
  • 1 × Car door lock actuator
  • 1 × H-Bridge motor controller transistor driven
  • 1 × Mic preamplifier Compatible with arduino based on LM358 opamp
View all 8 components
  • Enhancement ideas
    Debojit Kundu09/06/2016 at 07:34 0 comments
    The project is almost completed. I have planned for further enhancements:
    1. Add a camera-probably arducam
    2. With full duplex audio transmission over IP (VOIP), acoustic echo is unavoidable. So working on Speex library to port to esp8266
    3. Add a LIPO battery and charger for uninterrupted service.
    4. Adding a proper electronic door actuator instead of a car door lock actuator
    5. Adding IR support to know if the door is at latchable position.
View project log
  • 1
    Step 1
    Working on the full guide!!
View all instructions
