Random thoughts and findings
A project log for Šilelis 405D-RPI
All-in-one Raspberry Pi PC, based on Šilelis TV receiver
jurkstasjurkstas 04/14/2018 at 18:320 Comments
Found a Radio magazine article about a display that is based on same CRT tube and probably has same or similar electronics except TV RF part. I need to understand what kind of signal is needed for such display. RPI has multiple video outputs (depending on exact board model). Three potential candidates for this are composite output, DSI (Digital Serial Interface) and DPI (Digital Parallel Interface). Every one of them requires adapting and the analog output might not be the easiest one.
Some more reading:
RGB to composite IC
http://www.analog.com/media/en/technical-documentation/data-sheets/AD724.pdf
Triple video DAC:
http://www.analog.com/media/en/technical-documentation/data-sheets/ADV7120.pdf
