Attiny 85 Decade Counter
Get a reading from your decade counter with i2c!
Decade counters come with an 11 pin interface. One pin per value and a common ground. This seemed like a horrible waste and surely there is a way to make it easier and more useful to use.
Replacing the circuit board with a custom one wasn't a hugely difficult process.  603 SMD components were mainly used to keep the size down to fit in such a limited space.
The position the dial is at is dictated by a resistance wheel.  Each segment adds 220Ohms of resistance and checking this value using the internal voltage of the chip gives sufficient deviation to identify each position.
The WS2812b is included on the board and if the central dial is translucent the dial will glow.
  • 1 × http://www.adafruit.com/products/1082 Adafruit Mechanical Decade Counter
  • 1 × Attiny 85
  • 1 × WS2812b
  • 9 × 220 Ohm 603 resistors
  • 1 × 0.1uf 603 capacitor
View project log
