Mary PC v1.0
Maria PC Is a new kind of PCs in the old thinking of using a computer .
0 comments
2 followers
likes
Maria PC Is a new kind of PCs in the old thinking of using a computer ,
as a programmer , it'll be V. easy for me & the Alike people to use it & develop it , it's still in the paper section , but soon & as a graduation project in field of CS faculty
another target .... that's fired up this idea .... ::
our new students somehow in Egypt don't have more than the faculty fees , can't get a computer that can actually be their back bone for them till they can get a full function PC
the futures of the new Maria ::
+ Internet access to send emails & programming sketches to be compiled
+ can run on composite or vga
+ can be used separated from any other PC & just connected with the LAN & WAN
+ can be hacked ;) & developed
+ can run programs written in arduino cooding c++
Of-course It's build around the atmega328 ++ atmega128a
using the gamebuino bootloader
** the picture from the first f
the first ((untested)) Power Supply Board Have been Designed & It's Readdy To Be Eached Today .... I'll Put A Video Of Making It >>>> soon ... Wait For me & Mary PC
  • 1 × Atmega128a Electronic Components / Misc. Electronic Components
  • 2 × atmega328pu Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × ESP8266 wifi module
  • 1 × ps2 & usb F Connectors
  • 1 × CD4013 Electronic Components / Misc. Electronic Components
View all 7 components
  • Toggle on off Button
    yromea09/29/2016 at 22:44 0 comments
    a little dream is to stop using 2 states ((on-off)) buttons , and use just one bush button to toggle on & off states >
    so > i decided to use Flip-Flop circuit based on CD4013 IC
    and here is the board on frtizing
    note:: i also found that i'll maybe use a separated power plug for my Mary PC
    so >>> i designed a Quick breakout for it
    Here is a Photo
  • Power Supply
    yromea09/29/2016 at 21:44 0 comments
    As a Problem .... the wifi shield ESP8266-02 refused to run on a little AMPs Power Source .> so > I built Mary PC Power Supply ^_^ ...
    It can handle up to 1 Amp & 9 to 19 Volts ...
    outputs 5 v by 1Amp & 3.3V by 500MAmp
    Here is Some Photos ;) ::
View all 2 project logs
