ESP8266 Screen Set WiFi Credentials<br><br>Transfer data (WiFi credentials) from your smartphone to an ESP8266 by Pulsing your Smartphone Screen<br><br>To setup your WiFi Credentials put your ESP12F over a Smartphone screen, and let the Black and White Oscillation transmit the information. Note: You need to cover the LDR, in a way no light can enter. The LDR should not touch the screen, it needs stay some millimeters far from the screen.<br><br>Items required:<br><br>- ESP-12F (and all the basic componentes to make it work)<br>- Resistor 300k<br>- LDR 50K-50M Omhs (GL5539)<br>- Unzip the library ESP8266-screenSetWifi-master (attached in this projet) into your Arduino Library Folder<br><br>PS: You can try other variations of resistor values and LDR types. Just make sure the max resistive value of LDR is greater than the pull-down resistor.<br><br>Github: <br><br><a target="_blank" rel="noopener noreferrer" href="https://github.com/egzola/ESP8266-ScreenSetWifi">https://github.com/egzola/
Very cool! I tried this same thing last year and hadn't succeeded. I started with an LDR setup like yours and had terrible results. Moving to a phototransistor helped but I still never quite managed it. Time to revisit I guess.
Is it work like a scanner?can take a video,how it work?
