PET sheet build surface test
A project log for protoDEV 3d printer
diy direct-drive extruder 3D printer running Klipper firmware
michal-wojciechowskiMichal Wojciechowski 04/26/2018 at 17:070 Comments
If you want to perfect stick your 3d prints vinyl is cool but when printing with PET on vinyl you detach it with a piece of sandpaper ;)
SOLUTION: PET sheet. 3d Prints stick perfect and detach without any problems when heatbed is cooled down.
