New addon parts and test printing log
A project log for protoDEV 3d printer
diy direct-drive extruder 3D printer running Klipper firmware
michal-wojciechowskiMichal Wojciechowski 06/22/2018 at 10:210 Comments
When changing the fillament spool you needed some tricks and it wasn’t simple as it should be. It really was pissing me off.
Figured out a very simple solution.
Added an magnetic connection between spool system and the filament sensor. Now it’s changing spools is super simple... You can even take out the whole spool system.
