Building an Interpreter
A project log for 8 Bit TTA Interpreter
TTA (Transport Triggered Architecture) is very simple CPU type.
agpcooperagp.cooper 04/30/2018 at 10:570 Comments
Writing micro-code for an interpreter needs to done in incremental steps to avoid possible insanity by the author (some say it is too late)! So here are the stages that I used:
  1. Micro-code address (addr) counter
  2. Basic interpreter with inline (micro-code) op-code
  3. Interpreter with inline (micro-code) counter
  4. Interpreter with inline (micro-code) counter and jmp_adr op-code.
  5. Interpreter with op-code inc_addr.
  6. Interpreter with op-code  call and  rtn (return) op-codes.
The micro-code address (addr) counter
Here is the micro-code:
LABEL     ADR  ASM    COMMENT           ADDR CODE
COUNT     128  _0     Initalise         0X80 0X96
          129  REGD                     0X81 0XFB
          130  _0                       0X82 0X96
          131  ADDR                     0X83 0XF2
SHOW      132  ADDR   Show Address      0X84 0XF2
          133  REGA                     0X85 0XFA
INCREMENT 134  _1     Increment Address 0X86 0X95
          135  REGP                     0X87 0XF8
          136  ADDR                     0X88 0XF2
          137  REGQ                     0X89 0XF9
          138  ADD                      0X8A 0XF8
          139  ADDR                     0X8B 0XF2
DELAY     140  _255   255 MS DELAY      0X8C 0X94
          141  TEMP                     0X8D 0XF0
          142  SHOW   RETURN ADDRESS    0X8E 0X92
          143  RETURN                   0X8F 0XF1
          144  _96    DELAY SUBROUTINE  0X90 0X93
          145  JMP                      0X91 0XFF
          146  Const  _132              0X92 0X84
          147  Const  _96               0X93 0X60
          148  Const  _255              0X94 0XFF
          149  Const  _1                0X95 0X01
          150  Const  _0                0X96 0X00
I suspect that now you understand why micro-code is so unreadable. Let us look at lines 128 and 129:
This is how the coded needs to be analysed.
Label   Adr  Code     Comment                  Addr  Code
RESET   128  _255     SET JUMP TO JMP          0X80  0XDF
        129  JUMP                              0X81  0XF7
        130  _232     SET SP                   0X82  0XDE
        131  SP                                0X83  0XEE
        132  CODE     SET PC TO START OF CODE  0X84  0XDB
        133  IP                                0X85  0XEF
INTERP  134  IP       SAVE IP                  0X86  0XEF
        135  POINTER                           0X87  0XF6
        136  IP       INC IP                   0X88  0XEF
        137  REGP                              0X89  0XF8
        138  _1                                0X8A  0XDD
        139  REGQ                              0X8B  0XF9
        140  ADD                               0X8C  0XF8
        141  IP                                0X8D  0XEF
        142  _246     ^POINTER                 0X8E  0XDC
        143  JMP                               0X8F  0XFF
INLINE  144  IP                                0X90  0XEF
        145  JMP                               0X91  0XFF
CODE    146  144      &INLINE                  0X92  0X90
        147  NOP                               0X93  0X00
        218  NOP                               0XDA  0X00
        219  Const    _146                     0XDB  0X92
        220  Const    _246                     0XDC  0XF6
        221  Const    _1                       0XDD  0X01
        222  Const    _232                     0XDE  0XE8
        223  Const    _255                     0XDF  0XFF
The interpreter is remarkably simple:
  1. Set the jump to the address of the value pointed to by IP
  2. Increment IP to the next instruction
  3. Make the jump
The instruction just needs to return by jumping to the interpreter.
For the inline instruction, the instruction has to recalculate the address of the next instruction and set the IP.
Now it is staring to look interesting, it works but it does not appear to be very space efficient.
Interpreter with op-codes call/rtn/jmp/Include
Okay, while the above micro-code just fits into the available memory, the actual op-codes are only 5 bytes:
  1. Call
  2. Addr (4)
  3. Jmp_Adr (1)
  4. Inc_Addr (front panel)
  5. Rtn
The executed bytes (exclude the delay loop) is 136 while the Inc_Addr only is 14 bytes. So the interpreter is about 10x slower than native TTA micro-code.
Possible Interpreter Monitor
If I improve the hardware for I/O (serial perhaps?), I may be able to fit the above interpreter into ROM on the TTA8. Failing that it is time to design the TTA16.
AlanX
