The three PCBs:
- Original Viscount beats circuitry
- Stereo tube amp
- Power supply (AC 15V supplying direct to the amp, then rectifying to ~18V DC, supplying the +12V/-15V the Viscount board needs)
Building the case:
(kind of looks like a toilet seat here)
Then a ton of angle grinding. Every step of the case build made me appreciate why most boxes for things are, well, boxes: working with wood that curves in three dimensions is super annoying! You can't clamp it anywhere.
That said, it came out ok after all that:
Cutting the face:
Finally ready to put it all together…
And there it is: a triumph of impracticality… perfect for Hackaday :)
Charlie Williams
Rick Norcross
Yonghan
vybhav-nag
AccidentalRebel
Very cool! I'd love to hear how it sounds!
