Automatic fermenting box
a fermenting box use dht22 and a cheap humidifier to control humidity. use the sunshine to heat
Public Chat
0 followers
a fermenting box use dht22 and a cheap humidifier to control humidity. use the sunshine to heat. it's a poor project ,but i will improve it.
我的目的是为了制作一个在白天使用太阳来加热,通过湿度传感器控制加湿器的烟草发酵箱。箱子的主体是一个泡沫箱,我在里面铺上了锡箔(也可以是铝箔),箱子的开口使用了保鲜膜封住。这样可以更多的吸收太阳的热量,同时不让热量太快的流失。同时我使用8266模块,我可以在办公室来监测数据(io.adafruit)。目前我的设备已经开始运行。但是湿度变化曲线不是很理想。我就会调整我的代码来使湿度曲线更加的平滑。同时,目前的最高温度记录为44摄氏度,也没有达到目标的50度。英语不是我的母语,并且我也不想用英语来写这些,这对我来说太难了。所以提供了GOOGLE翻译的英文版本。
My purpose is to make a tobacco fermentation tank that uses the sun for heating during the day and controls the humidifier through a humidity sensor. The main body of the box is a foam box. I put a tin foil (which can also be aluminum foil) inside, and the opening of the box is sealed with a plastic wrap. This can absorb more of the sun's heat without losing too much heat. At the same time I use the 8266 module and I can monitor data (io.adafruit) in the office. At present my equipment has already started running. However, the humidity curve is not ideal. I will adjust my code to make the humidity curve smoother. At the same time, the current maximum temperature record is 44 degrees Celsius, and it has not reached the target of 50 degrees. English is not my mother tongue, and I don't want to write this in English. It's too hard for me. So the English version of GOOGLE Translator is provided.
  • 2018.6.1
    sunny06/01/2018 at 02:41 0 comments
    2018年6月1日
    通过一上午的数据观察,我发现了湿度下降率的大小与温度并没有太多的关系,而是与温度呈现上升或下降的趋势有很大关联。当温度下降时,湿度会很慢的下降甚至上升,当温度快速上升时,湿度会快速的下降。不过我并不打算计算他们的具体关系,因为这是一个复杂的数学问题并且对我的项目影响不大,我只需要减少加湿器单词启动的运行时间,并且给他一个合适的等待时间。这段时间用来弥补传感器对环境湿度读取的延迟。总之,修改代码之后,湿度的浮动区间将会缩小,但无法消除!
    Through one morning's data observation, I found that the rate of humidity drop has little relationship with temperature, but it is closely related to the tendency of temperature to rise or fall. When the temperature drops, the humidity will drop very slowly or even rise. When the temperature rises rapidly, the humidity will drop rapidly. However, I do not intend to calculate their specific relationship, because this is a complicated mathematical problem and it has little impact on my project. I only need to reduce the running time of the humidifier word and give him a suitable waiting time. This time is used to compensate for the sensor's delay in reading ambient humidity. In short, after modifying the code. The range of humidity will be reduced, but it cannot be eliminated!
View project log
