Colonisation.dxfAn example of the dxf code.AutoCAD DXF - 249.76 kB - 06/07/2018 at 13:40 |
colonisation2dxf.cExport DXF code as well.x-csrc - 11.51 kB - 06/07/2018 at 13:39 |
dxf.cMy dxf line (segment) codex-csrc - 3.56 kB - 06/07/2018 at 10:37 |
dxf14.pdfIn case you need to find out something (best of luck)Adobe Portable Document Format - 1.52 MB - 06/07/2018 at 10:35 |
test.dxfA polyline testAutoCAD DXF - 21.98 kB - 06/07/2018 at 10:35 |
dxf_polyline.cMy polyline code (export)x-csrc - 3.62 kB - 06/07/2018 at 10:35 |
Using.txtxbgi install and usingplain - 6.48 kB - 06/05/2018 at 14:25 |
libXbgi.aThe xbgi libraryx-archive - 242.40 kB - 06/05/2018 at 14:23 |
graphics.hThe xbgi header filex-chdr - 13.52 kB - 06/05/2018 at 14:22 |
Functions.txtxbgi functionsplain - 4.19 kB - 06/05/2018 at 14:22 |
colonisation.cAn example of the codetext/x-csrc - 8.06 kB - 06/05/2018 at 14:22 |
