version 1 Bacteria Algae reactor 156 shapes.stlall 24 cells together for oxygen co2 resperation, cells piped to resevoir and small pump in those resevoirs. white is bacteria load and green is algae loadStandard Tesselated Geometry - 7.30 MB - 07/14/2018 at 16:05 |
U tube.stlThis is the U shaped salt bridge, I printed at low quality but may not be water proof, for best results print this peice on your finest settings with no supports, add a brim.Standard Tesselated Geometry - 25.08 kB - 07/11/2018 at 13:53 |
1st try bio reactor.stlno supports, print upright.Standard Tesselated Geometry - 2.23 kB - 07/11/2018 at 13:53 |
hollow electrode bioreactor.stlA hollowed out version of the electrode tube so it will print faster and use less filament.Standard Tesselated Geometry - 18.73 kB - 07/11/2018 at 13:53 |
electrode tube bioreactor.stlsolid with infil tube, easier to waterproof ,but uses more print time and filament.Standard Tesselated Geometry - 13.17 kB - 07/11/2018 at 13:53 |
