WitcherMedallion_Rev16.zip"Bekymmer utan lösningar"x-stuffit - 4.58 MB - 09/23/2018 at 17:04 |
WitcherMedallion_rev15.zipYes, it did! Here's a fixed version.x-stuffit - 4.63 MB - 09/08/2018 at 05:40 |
WitcherMedallion_Rev14.zipIt failed QA test so I modified the thing. This is gonna turn into a disaster, isn't it?!x-stuffit - 1.91 MB - 08/28/2018 at 06:32 |
WitcherMedallion_Rev13.zipNew board design. Hope it passes the QA this time!x-stuffit - 1000.93 kB - 08/27/2018 at 18:38 |
Medallion_FW_v1.5.zipNew version with watchdogs timer issue resolved.x-stuffit - 6.55 kB - 08/27/2018 at 18:38 |
MedallionFW-v1.0.7zThe firmware for the medallion. Check the comments for credits and don't spoil the "surprise"!7-Zip - 3.53 kB - 08/26/2018 at 08:30 |
WitcherMedallion_Rev12.zipAnother day, another updatex-stuffit - 796.76 kB - 08/23/2018 at 09:50 |
WitcherMedallion_rev11.zipChanges were made.x-stuffit - 760.84 kB - 08/18/2018 at 08:17 |
WitcherMedallionRev10.zipI feel that this is nearing the end!x-stuffit - 553.94 kB - 07/10/2018 at 17:53 |
WitcherMedallionRev9.zipIncludes the back daughter board to shield the components from fingers. The footprints on the daughter board are just for the show.x-stuffit - 463.64 kB - 07/10/2018 at 14:17 |
WitcherMedallionRev8-A.zip(Diagnosis use only)x-stuffit - 261.50 kB - 07/09/2018 at 05:10 |
CDPR.aiAll graphic assets, ready to export via Bitmap2Component. Readable on Adobe Illustrator CS6 and above.postscript - 401.56 kB - 07/08/2018 at 16:28 |
WitcherMedallionRev8.zipAttempting to fill the ground plane freezes the program, but here it is, all wired up except for ground. I guess the track is a bit too thin here and there, and they will be fixed.x-stuffit - 261.50 kB - 07/08/2018 at 16:28 |
WitcherMedallionRev7.zipGoing fast now, does anyone have a spare engineer or two?x-stuffit - 256.34 kB - 07/08/2018 at 13:39 |
WitcherMedallionRev6.zipThe circuit is a big mess but in theory it may work. (Note: The antenna's integrity is compromised due to the placement of the LEDs, which will be pulsed on and off at high frequency. This issue will be addressed in the revision 7)x-stuffit - 179.69 kB - 07/08/2018 at 04:47 |
WitcherMedallion_rev5.zipCurrent state of the project file, as of July 7, 2018. Note: The circuit has problems that are not addressed yet.x-stuffit - 171.46 kB - 07/07/2018 at 17:36 |
WitcherMedallionRev4.zipCurrent state of the project file, as of July 6, 2018.x-stuffit - 20.84 kB - 07/06/2018 at 09:55 |
