Software devlopment
A project log for SolarCharger SZBK07V2
A MPPT solar charger using a DC converter, MOSFET diode, Arduino Nano for control and an MPPT software library for simple integration.
keithhungerfordkeith.hungerford 07/16/2018 at 01:540 Comments
15 July. Working on software – initial version now complete and started testing / debugging
Set up breadboard with Arduino,  voltage dividers and current shunt amplifier, and connected with the SZBK01. The breadboad modeel uses a schottky diode instead of the MOSFET diode at this stage to reduce build time.
