MOSFET diode simulation and update
A project log for SolarCharger SZBK07V2
A MPPT solar charger using a DC converter, MOSFET diode, Arduino Nano for control and an MPPT software library for simple integration.
keithhungerfordkeith.hungerford 07/28/2018 at 13:040 Comments
I simulated a simpler MOSFET diode control circuit suitable for this design. The updated design uses two 2N7000 MOSFETs in the control circuit. With these MOSFETs there is no need for additional voltage protection diodes which were needed in the original design, so overall the performance is maintained with a simpler circuit.
