You Are Here
A project log for VoiceBox
Adding a Flask web interface (and other stuff) to the Google AIY Voice Kit.
tmTM 08/28/2018 at 22:260 Comments
I've made a lot of posts in this project and the Hackaday.io inteface doesn't seem to allow creation of an index. So here's a summary of logs so far:
In each case you should look at the logs before and after that linked for context and follow-up.
I must admit that I'm stalling a bit. I have lots of ideas for extending the project, but all the worthwhile ones are contingent on building a fresh Raspbian image with fully up-to-date Google API libraries and Numpy. I should also make sure that everything runs on Python3 (before f-strings break library compatibility again).
The next post will probably be a long, rambling, open-ended log of my steps in building the new image, I'll try to tidy and summarize in a later post, once everything's (hopefully) working.
Python 2 vs. Python 3 [Dramatized]
