Received the boards
10/10/2018 at 10:51 • 0 commentsHey, I finally came back to the project after a while, and received the boards recently. Altough there's a little error, the reset button which isn't connected to the right pin, but appart from that, the board works pretty well.
I've soldered it and have been working for about a week on the API, which includes the definitions for each pin, according to the shield pinout. The code is available here : https://github.com/EtienneDx/QuickProjectBoardV1
I'll add some examples later, and add the latest board gerber files :)
