Square Inch Tracker
A device that can send a position, u can use this for track people, pets, cars...
actually no big description for this project.
Global IoT Modem, Global eSIM, GPS module, Microcontroller and passive components that make everything works.
for years I've been dreaming with make a mini tracker, but components like modems and GPS/GNSS was too big for that project, in the last square inch contest I just stayed watching because in that moment was impossible fit all components in just one square inch, now I have this new opportunity and I introduce to all of you my one square inch tracker.
This device are very simple, everything starts when plug the usb,  at this time the device starts to charge a battery through the TP4056 thats are configured for charge at 450mA, at the same time the whole circuit is feeded and microcontroller are ready for work.
Microcontroller operate Modem and GPS module.
When you plug usb to your computer the FTDI create a VPC so you can communicate with the microcontroller through a terminal like hyperterminal, putty, docklight... the commands for the device are not created yet, the idea is configure the device for first time, telling him ip address, port etc...
microcontroller knows the state of the battery(charging/standby), in the beginning the mcu could read battery voltage but I couldn't fits that in one square inch so...
well I think this is all about my device i hope some of you are interested on follow this project until the end and I have to thank you for come to see.
Adobe Portable Document Format - 411.44 kB - 08/14/2018 at 19:18
Preview
Download
08_11_2018_1SQI_BOM.xls
Bill of materials
ms-excel - 33.50 kB - 08/12/2018 at 01:12
Download
  • 3 × CC0603MRX5R7BB106 CAP CER 10UF 16V X5R 0603
  • 8 × CC0402KRX7R7BB104 CAP CER 0.1UF 16V X7R 0402
  • 1 × UFM12PL-TP DIODE GEN PURP 100V 1A SOD123FL
  • 3 × MBRX160-TP DIODE SCHOTTKY 60V 1A SOD123
  • 1 × LTST-C190KGKT LED GREEN CLEAR 0603 SMD
View all 35 components
View all 6 project logs
