"There are no strings on me..."
It's now almost a year that I'm working on and off on the Redox project, however I keep asking myself: "How can I improve this design further?".
"Wireless" is the answer.
In the last few months I began researching how to make a split QMK-compatible keyboard wireless and the only answer was the Core51822(b) module (see the Mitosis for further details. On a side note: that keyboard is awesome!). Needless to say I ordered a few immediately and began experimenting.
Receiver
I began by replicating the receiver module using the available schematics from the Mitosis project.
I used a breadboard compatible version of the AMS1117 3.3 voltage regulator to power the Core51822 and for the remaining parts I used through-hole components I had laying around. I then realized the main drawback of using the Core51822: those damn 2.0mm pitch headers. I got a little creative with the hand soldering but for the keyboard matrix wiring I'll use some 2.0mm pitch to 2.54mm pitch jumpers I found on Amazon.
I then tested that everything was working with the usual led blink. To get to this point I used this excellent guide for the NRF51822.
Now it was time to wire the keyboard.
Transmitters
Since this is just a proof-of-concept I wanted to recycle my testing board before designing a new PCB from the ground up.
I then decided to create a sort of adapter for the Arduino Pro Micro to something that can be wired to the Core51822. I came up with the following:
I have a pin header row that fits inside the Pro Micro footprint, those pin are then wired to another row of pin headers that will be connected to the Core51822. I used a CR2032 to power the module.
