Beetje Bloks
Build a project bit-by-bit, making it easy to design, debug, and program. Electronics is hard unless you Keep It Simple Stupid.
Public Chat
What if breakout boards had a common footprint that matched a small dev board? You could design, build, and program larger projects in functional blocks and then synthesize the final project out of tested and characterized subsystems. Beetje Bloks are a test of that concept, warped into the Hack-a-day One Square Inch Scheme, otherwise known as "HADOSIS", because It all starts with an Atmel 32U4 dev board. In KiCad. Because For the One Square Inch contest, obviously only one board would count, and I would submit the 32U4 Blok for consideration.
Electronics can be frustrating with successes few and far between.  I’ve come to believe that the “Keep it Simple” philosophy is key, especially for beginners. Purposely limiting the circuit size and scope can greatly simplify development as each bite size portion of a larger project can be designed, debugged, and programmed independently.
This is really the Arduino + Shield system, only smaller.  An Arduino shield sized PCB is a bit expensive for iterating prototypes whereas one square inch is only $5 for three copies at OSH Park!  Most sensors work off I2C or SPI, and with a couple extra data and analog pins, we can cover a large number of uses with just a few pins.  Here is what I’m thinking for the basis of microcontroller development board:
  • USB ready (without FTDI!), so maybe 32U4 to start, SAM21 latter.
  • 3.3V for compatibility with sensors and low-power use.
  • 0.1” Pitch headers for breadboarding (and ability to route between pins).
  • Surface mount components capable of hand assembly (i.e. 0603 or larger, packages with leads where possible).
  • I2C and SPI pins.
  • Additional data (PWM please) and analog pins as will fit in the format.
Yes, commenters who didn’t read this far, there are already some very well designed dev boards that meet these requirements.  Adafruit’s IstyBitsy and Sparkfun’s Pro Micro are two well executed examples. And they are open source with Eagle files available, albeit without details about components typically found in bill of materials (BOM).  And while both companies provide excellent breakout boards with example software, they still need to be breadboarded or jumpered in to use. Here is what I’m proposing:
  • Open Source development board done in KiCad that comes with a full BOM, ready to drop into whatever project you need, either physically or into a schematic/PCB.
  • Ecosystem of breakout designs with standardized footprint that can either be physically plugged into the dev board, or the design into the schematic/PCB.
If you are still with me, let’s try a use case:  model rocket telemetry. I wanted to update one of my old projects (https://www.instructables.com/id/Radio-Telemetry-for-a-Model-Rocket/) using a dedicated PCB to improve ruggedness. Using the KISS principle, let’s break this into functional blocks (links to project logs as they are built and tested):
Ideally, we’d have a tested block for each piece and could immediately start writing firmware while combining the electrical designs into a single PCB.  Or maybe, we’d find a new sensor to try and would need to design and test a block for it.
Of course, since we are starting in the real world from ground zero (or near it), let’s start with the MCU block. If I can’t get that working, there is no point in moving forward.  And, since Hack-a-day is running another One Square Inch contest, let’s use that as the basis of the footprint.  We are going to build things bit-by-bit. Since I sell a disproportionate number of kits to the Netherlands, I’m going to call these "Beetje Bloks", which translates from Dutch to “bit blocks”.   I’m not sure how to pronounce it.  Let’s say it “Beet-Cha”, as in, “I betcha can’t design a one-inch square dev board”.
Current files on Github: https://github.com/aspro648/Beetje-Bloks
project V0-gerbers.zip
x-zip-compressed - 53.40 kB - 08/22/2018 at 05:01
Download
project.sch
Kicad Schematic File
sch - 21.12 kB - 08/22/2018 at 04:44
Download
project V0.kicad_pcb
Kicad PCB file. Upload this to OSHPark.com
kicad_pcb - 217.70 kB - 08/22/2018 at 04:43
Download
  • 1 × U1, Atmel ATMEGA32U4-AU https://www.digikey.com/short/jb25pc
  • 1 × U2, Microchip MIC5225-3.3YM5-TR https://www.digikey.com/short/jb2rq8
  • 1 × C7 1uF SMD 0603 https://www.digikey.com/short/j5d397
  • 1 × X3, CONN RCPT MICRO USB R/A SMD https://www.digikey.com/short/jb2205
  • 2 × R4, R5, 22 Ohm 5% 0603 SMD resistor https://www.digikey.com/short/jfcbtj
View all 15 components
  • OLED Display
    MakersBox09/12/2018 at 01:25 0 comments
    I wanted a small display. Adafruit has a 128x32.  SparkFun has a 64x48.  They both use SSD1306 driver chips.
    I found a company called Crystalfonzs that sells SSD1306 displays and even a dev board, very inexpensively.
    I bought a number of display modules with ribbon cable connectors .  This seems like a good route because while the connector adds expense, it allows the display to be changed and eliminates a nasty bit of hand soldering.
    All the displays work.  The libraries written by Adafruit and Sparkfun work well for the display size they sell, but modifying the code, or even rotating the screen is a bit beyond my coding level at this point.
  • Data Logging
    MakersBox09/09/2018 at 01:22 0 comments
    My only experience with SD cards and Arduino was with Adafruit's Wave Shield, so I knew you could at least read data.  An SD card seems like an ideal way to data log because you can remove the card and read it on a computer and not worry about having to transfer data via serial.  For long term data logging, I'm interested in power consumption.  For short term data logging (like model rockets), I'm interested in how fast I can write data.
    For the circuit, I copied Adafruit's Micro SD breakout, minus her five volt level shifting.  There is a SD library in the standard Arduino libraries.
    My first attempt using a 4 Gb card resulted in failure, and I'm not sure why.  I formatted the card using the official formatter recommend in Adafruit's tutorial.  The card was recognized by the Arduino, but wouldn't read or write and subsequent attempts to reformat were unsuccessful.
    I did a bit of a design review before throwing another card at it.  Nothing showed up, and my next attempt with a 2 Gb card was successful.  Was it Einstein who said "Insanity is doing the same thing twice while expecting different results"?  Welcome to crazy.
    I wrote some test code to see how fast it was writing.  I can basically three data points 43 times a second, or once every 23 ms.  Not terribly fast, but fast enough?  We will have to wait for the EEPROM blok to do a comparison.
  • Under Pressure
    MakersBox09/07/2018 at 16:39 0 comments
    This whole project actually started by wanting to measure the vacuum inside a bottle without any bulkhead penetrations.  It needed to fit through an opening smaller than most dev and breakout boards, so I was looking to combine a Atmega328 and a sensor on a narrow PCB.  Creating square circuit boards is just a diversion for now.
    There are a number of pressure sensors with good Arduino libraries.  To date, I've worked with the MPL3115A and the MS5803, which are at the high end of price and capability.   Here is a little survey I did.
    The MS5637 or LPS25HB look like better choices for price and performance.  I also need to investigate the difference in speed between I2C and SPI.  For rocket telemetry, we want to focus very intently on a very brief duration event and that might be a factor. I'm sure that will play in to the EEPROM verses SD card choice as well.
  • LiPo Battery Power
    MakersBox09/07/2018 at 01:00 0 comments
    I love coin cells, but I'm not sure they will cut it if we need to do something more current intensive (like write to SD cards).  I shopped around and found a small square LiPo battery that will fit the footprint.  With only 150 mAh, it is not going to do a whole lot for a whole while, but it is a start.
    The charging circuit I borrowed from Adafruit's Trinket Backpack.  I put connectors on it for both JST PH and SH, the former seeming to be the most popular for LiPo batteries, the latter being what the battery I selected came with.   The unpopulated PH header can also act as test points or solder connections.
    I released my first bit of magic smoke on this project by hooking the battery in without checking the leads match the markings on the board. The back current immediately fried the MCP73831 and burnt my finger, all in the process of about two seconds.  Hum, maybe a protection diode or PTC? I've learned that lesson the hard way more than once.
    I am having an issue with the red charge light being dimly lit after disconnecting the USB power. I believe the battery diode D4 on the 32U4 board is leaking stray current back into the circuit. More on that latter.  I'm also wondering why the heck I didn't think to put a power switch on this board (or the 32U4 for that matter).  The headers and location are also not sorted yet.  I'm either going to use through-header so it will go on top of the 32U4 board, or piggy-back the 32U4 on top of it in a more permanent arrangement.
  • Battery: Swing and a Miss
    MakersBox08/28/2018 at 20:33 0 comments
    The battery and accelerometer boards came in at the same time.  The accelerometer worked, the battery, not so much.
    The first problem is that fitting a 20mm coin cell into a square inch with headers on each side is a loosing battle.  My idea was to drop the front six pins to allow entry and to angle the holder so the battery would not short out on the back header.
    The main board requires insulation such as electrical tape to keep from shorting the bottom of the front bus pins on the battery holder.  Minor issue.  I also somehow managed to get the battery backward in the schematic, requiring some trace cutting and bodge wire.  The good news is that per the whole KISS principle, I'm only out $5 in PCB and an hour of screwing around trying to figure out why ground and VCC were shorted even after I cut the traces (its the vias, dumbass).
    Next up?  RTC or pressure.
  • Acceleration. First Blok. First Success.
    MakersBox08/28/2018 at 20:18 0 comments
    In an earlier attempt at an integrated breakout board, two of the four I2C subsystems failed to work.  The accelerometer was one of them, so I figured it would be a good acid test. If you go to SparkFun or Adafruit, you will so a whole plethera of breakoutboards, so it is a bit hard to choose.  I decided on the LIS3DH because it was I2C, read up to 16g, and was fairly inexpensive.  Another thing you will quickly recognize is that all of them are some form of BGA package, making hand assembly difficult (and ultimately why I failed earlier).
    For hand soldering BGA, you pretty much have two choices:  hot air or reflow.  Either way, you life will be easier if you have a stencil.  I get mine from OSH Stencil.  I was already getting a stencil for another board, and just threw the footprint on.  The other resistors and capacitors were hand soldered.
    One of the advantages of using something SparkFun or Adafruit has done, is using their libraries. For the LIS3DH, there are actually two:
    https://learn.adafruit.com/adafruit-lis3dh-triple-axis-accelerometer-breakout/arduino
    As for headers, as you will see with the battery problems, I'm still trying to figure it out.  For now, I'm going with female on the main board (like Arduino) and male on the Bloks.  I'm going to try and source some shorter headers.
  • Beetje 32U4 Blok
    MakersBox08/22/2018 at 01:52 0 comments
    So again, for those commenters who didn’t read this far, I don’t think a 32U4 dev board is my gift to mankind. In fact, even copying Adafruit’s IstyBitsy straight into KiCAD is going to be at the limits of my ability.  I like the IstyBitsy’s power management and reset button and the Pro Micro’s LEDs and polyfuse so I am going to fuse those together (pun intended).
    The physical layout is actually pretty easy since I’ve got a defined board space and pin spacing.  I want to make it so the bloks cannot be put in backward, so I’ll put eight pins on top row, six on the bottom row (wow, echos of Arduino here?).  This will also allow us to use standard Arduino through headers if we start start stacking. We need:
    • Power: VBus (USB 5V), VCC (3.3V), Vbat, Gnd
    • I2C: SDA, SCL
    • SPI: MOSI, MISO, SCK
    • Digital I/O: D9, D10 (both PWM)
    • Analog I/O: A0, A1
    With a RST pin, that makes 14.  That, like the size, feels just right for keeping us focused on keeping it simple.  If we need anything more I/O intensive like an LED matrix, it will have to be driven by SPI or I2C.  I’ve tried to follow the schematic flow for the physical layout, with power on the left and outputs on the right, although I’m sure that convention will break down quickly in places.
    Beetje 32U4 Blok Rev 0.0 Doing the Blink
    Since we’ve already admitted to ripping off borrowing from SparkFun, we might as well use both their 32U4 bootloader (https://github.com/sparkfun/Arduino_Boards) and their instructions for flashing it (https://learn.sparkfun.com/tutorials/installing-an-arduino-bootloader). I placed the ISP header located under the chip and used and my Programming Shield ( https://www.tindie.com/products/MakersBox/yet-another-programming-shield/) with Nick Sayer’s pogo kit (https://www.tindie.com/products/nsayer/avr-isp-pogo-adapter-kit/).  There could, in theory, be a dedicated AVR programming blok that would plug into the MCU board to program it, but that is a bit “cart before the horse” at this point.
    • Rev 0.0 works (see photo) with no bodge wire!  The only issue is the ISP marks on the silk screen were swapped.  I've fixed that in the board file.
    • Rev 0.1 (see rendering) moves the power diodes and polyfuse to the front to make it easier to assemble with reflow. Minor changes to chip positions. No change to header pinouts (yet).
    Notes:
    • Provisions for 5V operation at 16 Mhz are provided, but haven't been tested.
    • I like the right-angle button idea, but not the "feels" of the actual button operation. Any suggestions?
    Now, off to design the next blocks for the rocket project and see if this takes off (pun intended) . . .
View all 7 project logs
