New Boards, Changes & Testers
A project log for Thunder pack
A kick-ass powered ARM board with everything you need all in a compact package that fits in your pocket.
JeremyJeremy 10/04/2019 at 13:351 Comment
The boards have arrived! I haven't assembled any yet, but everything is feeling a lot more polished.
Beta Testers
Now that the boards are close to completion, I've reached out to some friends and asked them to give them a spin and put them through their paces. I'm excited to get their feedback.
If you're interested to be a beta tester, let me know and I'll help you get setup.
Now 100% more dongle & sewable
The new batch has a hole at the end so it can be hung from a carabiner and notches if it will be sewn to something. The dongle hole can be removes from the board with a pair of diagonal cutters, if it's unnecessary.
Debug Changes + More GPIO
When I moved from 4 layers to 2 layers, space got tight and I had to move the JTAG/SWD pins to the bottom of the board, under the switch (assuming you'd have the switch on top and the debug headers on the bottom). At the time I thought this was a clever way to save some space and keep the layout tidy.
While waiting for the new round of boards, I've been working on writing a decent WS2812B addressable LED example and have been using the debugging interface quite a lot. It's become clear that having the debug pins on the bottom means you cannot debug AND be on a breadboard; which is inconvenient.
So last night I rerouted things.
Now, instead of a dedicated JTAG/SWD block, the necessary 3 pins (reset, PA13, PA4) have been added to the GPIO rows. The happy side-effect is now the board has 2 additional GPIO pins to use!
Next Round of Boards...
I'm controlling my twitchy finger from ordering a new batch of boards with the latest routing. First, I want to build a couple boards from this batch, run them through some tests and get the WS2812B example working.
pundittech wrote 10/14/2019 at 06:01 point
Would love to be part of beta testing and volunteering. :)
