Phoebe Spine.stlSTL for Phoebe's main backbone structure. Will need to be printed with support.Standard Tesselated Geometry - 1.57 MB - 10/16/2018 at 18:58 |
Phoebe 1.0.stepSTEP file exported from Onshape CAD. (See links section.)step - 2.43 MB - 10/16/2018 at 18:58 |
Phoebe Electronics Tray.stlSTL for Phoebe's tray for Raspberry Pi 3, Roboclaw motor controller, 5.0V and 3.0V voltage regulators. Can be printed with sloped bottom side facing print bed.Standard Tesselated Geometry - 817.37 kB - 10/16/2018 at 18:58 |
Phoebe LIDAR Front Support.stlSTL for a bracket that clips on to the backbone structure and supports front of Neato LIDAR unit. Designed to be printed upside down without supports.Standard Tesselated Geometry - 122.84 kB - 10/16/2018 at 18:58 |
