video!
09/18/2018 at 19:47 • 0 commentsFull video here of what it can do here:
Complete
09/17/2018 at 17:12 • 0 commentsTD404 is Complete.
Finishing up
09/16/2018 at 13:40 • 0 commentsAfter a bit of calibration, I have the preamp at its most efficient level for the delay module. I'm going to run a few test runs, but I will have a proof of concept video in the next log. This should be followed by the required video submission for the Hackaday2018 Musical instrument contest
TEETH
09/15/2018 at 13:53 • 0 commentsSo this log is unique to my project. Using a diamond bit, I drilled holes in some of my old wisdom teeth. Using hot glue, I am fixing them to the buttons for the warp and feedblast mods. (TD404-Tooth Decay404)
Preamp
09/15/2018 at 13:51 • 0 commentsIn order to get the most out of this contact microphone, I'm using a Velleman Preamp. It's very small and should help boost the sound. I'm not thrilled about the high end distortion that will probably result, but I think a simple RC Lowpass filter can solve it if it proves to be unbearable.
Wiring
09/15/2018 at 13:50 • 0 commentsAll pots are wired. Next is the modifications on the PCB and then wiring up the power supplies.
Fitting the Delay Module
09/14/2018 at 12:56 • 0 comments -
Box construction
09/11/2018 at 15:07 • 0 commentsI've begun adding the top layer components to the box I picked up from a thrift store.
Test Run 2: The Spring Machine
09/11/2018 at 14:57 • 0 commentsAgain, I am testing the ability of the concept.
Test Run: The String Machine
09/11/2018 at 14:55 • 0 comments
