• 1
    Demonstration Video
  • 2
    The Base CNC Machine
    On August 14, 2018 I published a project the featured a DIY Universal CNC machine. Its tools could be interchanged easily. Building the machine is quite complex, so see this project for further instructions.
  • 3
    Improving the Machine
    My initial project did have some flaws, however, as brought to my attention in the comments section of it. For one, the X axis belt had uneven tension. This could cause the movements to not be as precise. The X axis carriage also didn't fit onto the rail tightly enough, causing the entire assembly to tip over and grind against the rail. To fix this I completely redesigned the X axis carriage block by moving where the timing belt fits in and moving the V slot wheels to better locations, as well as adding another wheel to the back to prevent tilting.
