SilentELWireInterver_Datasheet.pdf
Simple Datasheet with Wiring Diagram
Adobe Portable Document Format - 959.62 kB - 09/30/2019 at 03:40
Preview
Download
QUIET_EL_POW.pdf
Current Schematic for the Design.
Adobe Portable Document Format - 50.38 kB - 09/07/2019 at 04:22
Preview
Download
Quiet_EL_BOM.csv
Detailed BOM.
Comma-Separated Values - 1.03 kB - 09/07/2019 at 04:20
Download
These two ghosts are powered by this circuit. They have about 28-33nF of cable in each. They ran about 290-300Vpp, instead of the full 360Vpp. I lowered frequency to 1kHz to help voltage.
JPEG Image - 244.13 kB - 11/02/2018 at 03:09
Preview
Download
The moon is powered by this circuit, the rocket and spider web are powered on off the shelf inverters. The rocket runs are full brightness, and 2kHz.
JPEG Image - 133.73 kB - 11/02/2018 at 03:09
Preview
Download
ASSEMBLY.asm
This code is not optimized for any particular inductor mosfet pair. It does control the voltage well, just needs to be optimization.
asm - 558.00 bytes - 10/14/2018 at 02:18
Download
EL_POW_USB_POW_SCH.pdf
Here is the schematic. The best inductor and MOSFET choice has not determined. There is a very simple assembly code frame work attached as well. The code, inductor & MOSFET are all related, and must be optimized. But the code was very simple to change.
Adobe Portable Document Format - 48.74 kB - 10/14/2018 at 02:01
Preview
Download
QuietVsNoisy1.mp4
Video of a AA battery EL inverter next to the quiet one. i don't know the brand of the batter powered one, I know it is very common. I took the video on my phone, the picture are not awesome but it does show the difference in noise level.
MPEG-4 Video - 44.67 MB - 10/13/2018 at 02:30
Download
