casing.svgTemplate for keybot casing. Laser cut from 3mm plywood.svg+xml - 84.99 kB - 10/05/2018 at 20:35 |
stand.svgTemplate for keybot tentacles. Laser cut from 3mm plywood.svg+xml - 53.91 kB - 10/05/2018 at 20:35 |
arms.svgTemplate for keybot fingers. Laser cut from 3mm plywood or acrylic.svg+xml - 17.39 kB - 10/05/2018 at 20:35 |
