pi_holder.stlThis is the bracket that holds the Raspberry Pi Zero against the case. The model was edited using Solvespace, this is the STL file ready to be passed to any 3d-printing software like Cura.Standard Tesselated Geometry - 28.01 kB - 10/25/2018 at 13:53 |
mount.stlThis is the bracket that holds the camera against the case. The model was edited using Solvespace, this is the STL file ready to be passed to any 3d-printing software like Cura.Standard Tesselated Geometry - 29.18 kB - 10/25/2018 at 13:53 |
mount.slvsThis is the bracket that holds the camera against the case. The model was edited using Solvespacex-solvespace - 273.08 kB - 10/25/2018 at 13:52 |
pi_holder_assembly.slvsThis is the bracket that holds the Raspberry Pi Zero against the case. The model was edited using Solvespacex-solvespace - 408.61 kB - 10/25/2018 at 13:52 |
x-solvespace - 194.80 kB - 10/25/2018 at 13:52 |
x-solvespace - 131.02 kB - 10/25/2018 at 13:52 |
