C-Sourcecode, not finished.. too big differences between Java regex and C Regex.
Seperates all Networks in every block and save the references,text in 2 Tables.
Builds a new file from SQLITE Data
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <cstring>
#include <iostream>
#include <list>
#include <map>
#include <regex>
#include <iterator>
#include <string>
#include <sqlite3.h>
#include <algorithm>
#include <time.h>
#include <unistd.h>
#include "main.h"
#include <fstream>
using namespace std;
static const string HEADER1     = "<!DOCTYPE html><html lang=\"de\"><head><meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\"/><title>S5Parser</title><style>\n";
static const string STYLEZUORD  = "pre{\nfont-size: 14px;\n\n} \na:link { background: lightgrey; text-decoration: none; color: black; }\na:visited { background: lightgrey; text-decoration: none; color: black; }\n\n/* The navigation bar */\n.navbar {\n    overflow: hidden;\n    background-color:  lightgrey;\n    position: fixed; /* Set the navbar to fixed position */\n    bottom: 0; /* Position the navbar at the top of the page */\n    width: 100%;\n    height:4%;\n    z-index:10;\n}\n\n/* Links inside the navbar */\n.navbar a {\n    float: left;\n    display: block;\n    color: #red;\n    text-align: center;\n    padding: 10px 16px;\n    text-decoration: none;\n}\nbody{\nmargin:0;\npadding:0;\n}\n/* Change background on mouse-over */\n.navbar a:hover {\n    background: #888888;\n    color: black;\n}\n.right{\n\nright: 0;\nwidth:50%;\nheight:100%;\noverflow-y: none;\nposition: fixed;\n\n}\npre{\nmargin-left:10px;\n}\n.Zuordnung {\n\noverflow-y: scroll;\nbackground: #EEEEEE;\nheight:96%;\n}\n/* Main content */\n.split{\nwidth:50%;\nheight:100%;\noverflow-y: scroll;\nposition: fixed;\n}\n.container{\nwidth:100%;\nheight:100%;\npadding:0;\n\n}\n\n.main {\nleft:0;\n\n   }";
static const string HEADER2     = "</style></head><body>\n\n<div class=\"container\">\n<div class=\"main split\"><pre><a href=\"#\" id=\"bausteine\"></a>";
static const string CONTENT     = "</pre></div>\n<div class=\"right\">\n<div class=\"Zuordnung\" ><pre>";
static const string FOOTER      = "</pre></div>\n<div tabindex=\"1\" class=\"navbar\"><a href=\"#ZLE\" tabindex=\"10\" onclick=\"\">Eingänge</a><a href=\"#ZLA\" tabindex=\"10\" onclick=\"\">Ausgänge</a><a href=\"#ZLM\" tabindex=\"10\" onclick=\"\">Merker</a><a href=\"#ZLS\" tabindex=\"10\" onclick=\"\">Ersatzmerker</a><a href=\"#ZPB\" tabindex=\"10\" >Bausteine</a><a href=\"#ZPT\" tabindex=\"10\" >Timer</a><a href=\"#ZPZ\" tabindex=\"10\" >Zähler</a></div>\n</div></div></body></html>";
static const string STYLESINGLE = "pre{\nfont-size: 14px;\nmargin-left:10px;\n}\n.tooltip {\n    position: relative;\n  display: inline-block;\n}\n\n.tooltip .tooltiptext {\n    visibility: hidden;\n    /*width: 60px;*/\n    background-color: #555;\n    color: #fff;\n   text-align: center;\n   padding: 5px 0;\n    border-radius: 6px;\n\n    /* Position the tooltip text */\n    position: absolute;\n    z-index: 1;\n    bottom: 125%;\n    left: 50%;\n    margin-left: 0px;\n\n    /* Fade in tooltip */\n    opacity: 0;\n    transition: opacity 0.3s;\n}\n\na:link { background: lightgrey; text-decoration: none; color: black; }\na:visited { background: lightgrey; text-decoration: none; color: black; }\n\n.navbar {\n    overflow: hidden;\n    background-color:  lightgrey;\n    position: fixed; /* Set the navbar to fixed position */\n    bottom: 0; /* Position the navbar at the top of the page */\n    width: 100%;\n    height:4%;\n    z-index:10;\n}\n\n.navbar a {\n    float: left;\n    display: block;\n    color: #red;\n    text-align: center;\n    padding: 10px 16px;\n    text-decoration: none;\n}\n\nbody{\nmargin:0;\npadding:0;\n}\n\n.navbar a:hover {\n    background: #888888;\n    color: black;\n}\n\n.right{\ndisplay:none;\nright: 0;\nwidth:0%;\nheight:100%;\noverflow-y: none;\nposition: fixed;\n}\n\n.Zuordnung {\noverflow-y: scroll;\nbackground: #EEEEEE;\nheight:96%;\n}\n\n.split{\n\nheight:100%;\noverflow-y: scroll;\nposition: fixed;\n}\n\n.container{\nwidth:100%;\nheight:100%;\npadding:0;\n}\n\n.main {\nleft:0;\nwidth: 100%;\n}\n";
static string fileoutput        = HEADER1;
int loadOrSaveDb(sqlite3 *pInMemory, const char *zFilename, int isSave);
string networks_get_links(int pb, int nw, string eam);
int db_select_match_insert(int pb, int nw, string eamname);
string networks_search_eam(int pb, int nw, string s);
int cb_networks(void *NotUsed, int argc, char **argv, char **azColName);
int callback(void *NotUsed, int argc, char **argv, char **azColName);
sqlite3 *db; //unclosed Memory Database
char *zErrMsg = 0; //DB Error Var
int rc;
static string newHtml = "";
char *file1;
char *file2;
char *file3;
bool single=false;
static string getNetworksTable() {
    int lastpb;
    string networks = "";
    char query[] = "select pb,nw,code FROM networks ORDER BY pb,nw;";
    sqlite3_stmt *stmt;
    int rc = sqlite3_prepare_v2(db, query, -1, &stmt, NULL);
    while ((rc = sqlite3_step(stmt)) == SQLITE_ROW) {
        char* s = (char*) sqlite3_column_text(stmt, 2);
        // int length=sprintf(NULL, "<a href=\"#\" id=\"pb%dnw%d\" ></a>", sqlite3_column_int(stmt, 0), sqlite3_column_int(stmt, 1)); /* 3 */
        string nwlink = "<a href=\"#\" id=\"pb";
        nwlink.append(to_string(sqlite3_column_int(stmt, 0)));
        nwlink.append("nw");
        nwlink.append(to_string(sqlite3_column_int(stmt, 1)));
        nwlink.append("\" ></a>"); /* 3 */
        //string nwlink = "<a href=\"#\" id=\"" + "pb" + rs.getInt("pb") + "nw" + rs.getInt("nw") + "\"></a>"
        //tempnw = tempnw.replaceAll("(.*Netzwerk.*)", "<h4>PB" + rs.getInt("pb") + " $1 </h4>");
        regex exp("(.*Netzwerk.*)", std::regex::ECMAScript);
        string stemp = s;
        string replacestring = "<h4>PB";
        replacestring.append(to_string(sqlite3_column_int(stmt, 0)));
        replacestring.append(" $1 </h4>");
        stemp = std::regex_replace(stemp, exp, replacestring);
        string pblink = "<a href=\"#\" id=\"pb";
        pblink.append(to_string(sqlite3_column_int(stmt, 1)));
        pblink.append("\"></a>");
        if (lastpb != sqlite3_column_int(stmt, 0)) {
            networks.append(pblink);
        lastpb = sqlite3_column_int(stmt, 0);
        networks.append(nwlink);
        networks.append(networks_search_eam(sqlite3_column_int(stmt, 0), sqlite3_column_int(stmt, 1), stemp));
    sqlite3_finalize(stmt);
    return networks;
string create_Network_Link(int pb, int nw, int text) {
    return 0;
string networks_search_eam(int pb, int nw, string s) {
    string pattern[] = {
        "([E][ ]{1,3}[0-9]{1,3}[.][0-7])",
        "([A][ ]{1,3}[0-9]{1,3}[.][0-7])",
        "([S][ ]{1,3}[0-9]{1,3}[.][0-7])",
        "([M][ ]{1,3}[0-9]{1,3}[.][0-7])",
        "([T][ ]{1,3}[0-9]{1,3})",
        "([Z][ ]{1,3}[0-9]{1,3})"
    string network = s;
    for (int n = 0; n < 4; n++) {
        regex rgx(pattern[n], std::regex::ECMAScript);
        auto words_begin =
                std::sregex_iterator(s.begin(), s.end(), rgx);
        auto words_end = std::sregex_iterator();
        for (std::sregex_iterator i = words_begin; i != words_end; ++i) {
            std::smatch match = *i;
            std::string matcher = match.str();
            regex exp(matcher, std::regex::ECMAScript);
            network = std::regex_replace(network, exp, networks_get_links(pb, nw, matcher));
    return network;
string networks_get_title(string eam) {
    string titleQuery = "select eamname,pb,GROUP_CONCAT(nw) AS nw FROM  (SELECT eamname,pb,nw FROM refs ORDER BY nw) WHERE eamname='";
    titleQuery.append(eam);
    titleQuery.append("' GROUP BY pb ORDER BY pb");
    int rc;
    const char* query = titleQuery.c_str();
    sqlite3_stmt *stmt;
    string ret;
        char* pbtext = (char*) sqlite3_column_text(stmt, 2);
        ret.append("PB");
        ret.append(to_string(sqlite3_column_int(stmt, 1)));
        ret.append(": ");
        ret.append(string(pbtext));
        ret.append("
    return ret;
string networks_get_links(int pb, int nw, string eam) {
    int rc;
    //cout << eam << endl;
    char query[200];
    regex exprRMHead2(" ", regex::ECMAScript);
    std::string eamclear = regex_replace(eam, exprRMHead2, "");
    std::string eamnbsp = regex_replace(eam, exprRMHead2, " ");
    const char* temp = eamclear.c_str();
    sprintf(query, "select nw,pb,eamname FROM refs WHERE eamname='%s' AND( (nw>%d  AND pb=%d) OR ( pb>%d))  ORDER BY pb,nw LIMIT 1;", eamclear.c_str(), nw, pb, pb); /* 3 */
    sqlite3_stmt *stmt;
    char ret[1000];
    if ((rc = sqlite3_step(stmt)) == SQLITE_ROW) {
        sprintf(ret, "<a href=\"#pb%dnw%d\" title=\"%s\" >%s</a>", sqlite3_column_int(stmt, 1), sqlite3_column_int(stmt, 0), networks_get_title(eamclear).c_str(), eamnbsp.c_str()); /* 3 */
        //cout << "FOUND:" << sqlite3_column_text(stmt, 2) << endl;
    } else {
        sprintf(query, "select nw,pb,eamname FROM refs WHERE eamname='%s' ORDER BY pb,nw", eamclear.c_str()); /* 3 */
        sqlite3_stmt *stmt2;
        int rc = sqlite3_prepare_v2(db, query, -1, &stmt2, NULL);
        if ((rc = sqlite3_step(stmt2)) == SQLITE_ROW) {
            sprintf(ret, "<a href=\"#pb%dnw%d\" title=\"%s\" >%s</a>", sqlite3_column_int(stmt2, 1), sqlite3_column_int(stmt2, 0), " ", eamnbsp.c_str()); /* 3 */
        } else {
            sprintf(ret, "%s", eam);
        sqlite3_finalize(stmt2);
    string returns = ret;
    return returns;
string zuordnungen_get_links(string eam) {
    int rc;
    char query[200];
    regex exprRMHead2("[ ]+", regex::ECMAScript);
    sprintf(query, "select nw,pb,eamname FROM refs WHERE eamname='%s' ORDER BY pb,nw LIMIT 1;", temp); /* 3 */
    sqlite3_stmt *stmt;
    char ret[1000];
    } else {
        return eamnbsp;
    return string(ret);
int db_select_match_insert(int pb, int nw, string eamname) {
    sqlite3_stmt *stmt;
    const char* p_c_str = eamname.c_str();
    const string check = "INSERT INTO refs ( id,eamname,pb,nw) SELECT ?1,?4,?2,?3 WHERE NOT EXISTS(SELECT 1 FROM refs WHERE pb =" + std::to_string(pb) + " AND nw=" + std::to_string(nw) + " AND eamname = '" + eamname + "');";
    const char* p_c_insert = check.c_str();
    sqlite3_prepare_v2(db, p_c_insert, -1, &stmt, NULL);
    sqlite3_bind_int(stmt, 1, 0);
    sqlite3_bind_int(stmt, 2, pb); /* 2 */
    sqlite3_bind_int(stmt, 3, nw);
    sqlite3_bind_text(stmt, 4, p_c_str, -1, SQLITE_STATIC); /* 3 */
    rc = sqlite3_step(stmt);
    if (rc != SQLITE_DONE) {
        printf("ERROR inserting data: %s\n", sqlite3_errmsg(db));
    return 0;
int insertrefs(int pb, int nw, string code) {
    string patterns[] = {
        "([S|E|A|M][ ]{1,3}[0-9]{1,3}[.][0-7])",
        "[ ]+([T|Z][ ]{1,3}[0-9]{1,3})[ ]",
        "([D|F|P][B|W|X][ ]{0,5}[0-9]{1,3})(([ ]|[^ ]))"
    for (int n = 0; n < 2; n++) {
        const string input = code;
        regex rgx(patterns[n], std::regex::ECMAScript);
        sregex_iterator it(input.begin(), input.end(), rgx);
        sregex_iterator reg_end;
        for (; it != reg_end; ++it) {
            std::string matcher = it->str();
            matcher = regex_replace(matcher, exprRMHead2, "");
            db_select_match_insert(pb, nw, matcher);
    return 0;
int insertnw(int pb, int nw, string code) {
    sqlite3_stmt *stmt;
    const char* p_c_str = code.c_str();
    sqlite3_prepare_v2(db, "INSERT INTO networks ( id,pb,nw,code) values (?1,?2,?3,?4);", -1, &stmt, NULL);
    int rc;
    char *sql;
    const char* data = "Callback function called";
    return 0;
int createTablesAndDB() {
    rc = sqlite3_open(":memory:", &db);
    if (rc) {
        fprintf(stderr, "Can't open database: %s\n", sqlite3_errmsg(db));
        return (0);
    } else {
        fprintf(stderr, "Opened database successfully\n");
    const char* CreateQuery = "CREATE TABLE IF NOT EXISTS refs(id int auto_increment,eamname varchar(255),pb int, nw int)";
    const char* CreateQuery2 = "CREATE TABLE IF NOT EXISTS networks(id int auto_increment,pb int,nw int, code longvarchar(20000))";
    rc = sqlite3_exec(db, CreateQuery, callback, 0, &zErrMsg);
    rc = sqlite3_exec(db, CreateQuery2, callback, 0, &zErrMsg);
    if (rc != SQLITE_OK) {
        fprintf(stderr, "SQL error: %s\n", zErrMsg);
        sqlite3_free(zErrMsg);
    } else {
        fprintf(stdout, "Table created successfully\n");
    return 0;
static int mycallback(void *data, int argc, char **argv, char **azColName) {
    int i;
    fprintf(stderr, "%s: ", (const char*) data);
    for (i = 0; i < argc; i++) {
        printf("%s = %s\n", azColName[i], argv[i] ? argv[i] : "NULL");
    printf("\n");
    return 0;
int readnetworks(int pb, string s) {
    //std::cout << "Aufruf" << endl;
    string clear = "";
    regex exprRMHead1{"[ ]+Blatt[ ]+[0-9]{1,3}[ \\r\\n]", std::regex::ECMAScript};
    s = regex_replace(s, exprRMHead1, clear);
    regex exprRMHead2("[ ]{0,3}(PB[ ]{1,3}[0-9]).*LAE.*", regex::ECMAScript);
    s = regex_replace(s, exprRMHead2, clear);
    smatch m;
    regex e("Netzwerk[ ]{1,3}([0-9]{1,3})[ ]+[0-9A-Z]{1,4}", regex::ECMAScript); //regex expr{"^[ ]+Blatt[ 0-9]+$",};
    //std::cout << output;
    sregex_iterator it(s.begin(), s.end(), e);
    string oldmatch = "";
    long startNW = 0;
    long newNWpos = 0;
    std::string lastNWtemp;
    regex rgx("Netzwerk[ ]{1,3}([0-9]{1,3})", std::regex::ECMAScript);
        newNWpos = it->position();
        const string network = s.substr(startNW, newNWpos - startNW);
        // std::cout << network << std::endl;
        startNW = newNWpos;
        std::smatch match;
        int networknumber = 0;
        if (std::regex_search(network.begin(), network.end(), match, rgx)) {
            networknumber = std::stoi(match[1]);
            //std::cout << match[0] << std::endl;
        //std::cout << networknumber << std::endl;
        insertnw(pb, networknumber, network);
        insertrefs(pb, networknumber, network);
    std::smatch match;
    int NW = 0;
    const string network = s.substr(startNW);
    return 0;
int createHtml() {
    return 0; //newHtml += htmlmenu;
string prepare_network_out(int pb, int nw, string network) {
    return 0;
string zuordnungen() {
    long length;
    FILE * f = fopen("SCHIFZLS.INI", "rb");
    char *buffer = 0;
    if (f) {
        fseek(f, 0, SEEK_END);
        length = ftell(f);
        fseek(f, 0, SEEK_SET);
        buffer = (char *) malloc(length);
        if (buffer) {
            fread(buffer, 1, length, f);
        fclose(f);
    if (buffer) {
        //printf(buffer);
    string clear = "";
    string s = buffer;
    regex exprRMHead1{".*Datei.*Blatt[ ]+[0-9]{1,4}.*", std::regex::ECMAScript};
    regex exprRMHead2(".*Operand.*Symbol.*Kommentar.*", regex::ECMAScript);
    regex exprRMHead3("([ ]+|>)([E][ ]{1,3}[0-9]{1,3}[.][0-7])", regex::ECMAScript);
    s = regex_replace(s, exprRMHead3, "<a href=\"\" id=\"ZLE\"><h4>Eingänge</h4></a><br><br>$0", std::regex_constants::format_first_only);
    regex exprRMHead4("([ ]+|>)([A][ ]{1,3}[0-9]{1,3}[.][0-7])", regex::ECMAScript);
    s = regex_replace(s, exprRMHead4, "<a href=\"\" id=\"ZLA\"><h4>Ausgänge</h4></a><br><br>$0", std::regex_constants::format_first_only);
    regex exprRMHead5("([ ]+|>)([S][ ]{1,3}[0-9]{1,3}[.][0-7])", regex::ECMAScript);
    s = regex_replace(s, exprRMHead5, "<a href=\"\" id=\"ZLS\"><h4>Ersatzmerker</h4></a><br><br>$0", std::regex_constants::format_first_only);
    regex exprRMHead6("([ ]+|>)([M][ ]{1,3}[0-9]{1,3}[.][0-7])", regex::ECMAScript);
    s = regex_replace(s, exprRMHead6, "<a href=\"\" id=\"ZLM\"><h4>Merker</h4></a><br><br>$0", std::regex_constants::format_first_only);
    regex exprRMHead7("([ ]+|>)([P][B][ ]{1,3}[0-9]{1,3})[ ]", regex::ECMAScript);
    s = regex_replace(s, exprRMHead7, "<a href=\"\" id=\"ZPB\"><h4>Bausteine</h4></a><br><br>$0", std::regex_constants::format_first_only);
    regex exprRMHead8("([ ]+|>)([T][ ]{1,3}[0-9]{1,3})[ ]", regex::ECMAScript);
    s = regex_replace(s, exprRMHead8, "<a href=\"\" id=\"ZPT\"><h4>Timer</h4></a><br><br>$0", std::regex_constants::format_first_only);
    regex exprRMHead9("[P][B][ ]{1,3}([0-9]{1,3})[ ]", regex::ECMAScript);
    s = regex_replace(s, exprRMHead9, "<a href=\"#pb$1\" >PB$1</a>", std::regex_constants::format_first_only);
    string input = s;
    for (int n = 0; n < 5; n++) {
        sregex_iterator it(s.begin(), s.end(), rgx);
            regex exprRMHead2(matcher, regex::ECMAScript);
            input = regex_replace(input, exprRMHead2, zuordnungen_get_links(matcher));
    return input;
int main(int argc, char* argv[]) {
    //  rc = sqlite3_open(":memory:", &db);
    // loadOrSaveDb(db, "/tmp/sq3test.db",0);
    // cout<<zuordnungen();
    if (argc < 2&& argc>4) {
        cout << "Zuwenig Argumente!!" << endl << "ConvertS5.exe PBDATEI ZUDATEI AUSGABEDATEI" << endl << "Ohne Zuordnungsdatei 0 eintragen";
        return 0;
    if(argc==3){
    single=true;
    file1 = argv[1];
    file2 = argv[2];
    }else
    file1 = argv[1];
    file2 = argv[2];
    file3 = argv[3];
    long length;
    FILE * f = fopen(file1, "rb");
    char *buffer = 0;
    if (f) {
        length = ftell(f);
        if (buffer) {
        fclose(f);
    if (buffer) {
        //printf(buffer);
    createTablesAndDB();
    // </editor-fold>
    regex expr{"^.*Blatt[ ]+[0-9]{1,3}.*$", regex::ECMAScript};
    string formatter = "";
    string output = regex_replace(buffer, expr, formatter);
    regex matcher2("<"); //"<",
    formatter = "<";
    output = regex_replace(output, matcher2, formatter);
    regex matcher3(">"); //"<",
    formatter = ">";
    output = regex_replace(output, matcher3, formatter);
    std::string s = output;
    smatch m;
    regex e("[ ]{0,3}(PB[ ]{1,3}[0-9]).*LAE.*", regex::ECMAScript); //regex expr{"^[ ]+Blatt[ 0-9]+$",};
    long startpb = 0;
    long newpb = 0;
    regex rgx("[ ]{0,3}PB[ ]{1,3}([0-9]{1,3})", std::regex::ECMAScript);
        if (oldmatch == it->str()) {
            const std::string st = it->str();
        } else {
            newpb = it->position();
            const string networks = s.substr(startpb, newpb);
            std::smatch match;
            int pbtemp = 0;
            if (std::regex_search(networks.begin(), networks.end(), match, rgx)) {
                pbtemp = std::stoi(match[1]);
                readnetworks(pbtemp, networks);
            startpb = it->position();
        oldmatch = it->str();
    std::smatch match;
    int pbtemp = 0;
    const string networks = s.substr(startpb);
    if(single)
        fileoutput.append(STYLESINGLE);
    else
        fileoutput.append(STYLEZUORD);
    fileoutput.append(HEADER2);
    fileoutput.append(getNetworksTable());
    fileoutput.append(CONTENT);
    fileoutput.append(zuordnungen());
    fileoutput.append(FOOTER);
    ofstream myfile;
    if(single)
    myfile.open(file2);
    else
    myfile.open(file3);
    if (myfile) {
        myfile << fileoutput;
        myfile.close();
    } else {
        std::cerr << "Failure opening " << argv[3] << '\n';
        return -1;
    return 0;
int callback(void *NotUsed, int argc, char **argv, char **azColName) {
    cout << argv[2] << "NW" << argv[3] << "EAM" << argv[1] << endl;
    return 0;
int cb_networks(void *NotUsed, int argc, char **argv, char **azColName) {
    cout << networks_search_eam(atoi(argv[1]), atoi(argv[2]), argv[3]);
    return 0;
static int cb_match(void *NotUsed, int argc, char **argv, char **azColName) {
    int i;
    printf("\n");
    return 0;
int loadOrSaveDb(sqlite3 *pInMemory, const char *zFilename, int isSave) {
    int rc; /* Function return code */
    sqlite3 *pFile; /* Database connection opened on zFilename */
    sqlite3_backup *pBackup; /* Backup object used to copy data */
    sqlite3 *pTo; /* Database to copy to (pFile or pInMemory) */
    sqlite3 *pFrom; /* Database to copy from (pFile or pInMemory) */
    /* Open the database file identified by zFilename. Exit early if this fails
     ** for any reason. */
    rc = sqlite3_open(zFilename, &pFile);
    if (rc == SQLITE_OK) {
        /* If this is a 'load' operation (isSave==0), then data is copied
         ** from the database file just opened to database pInMemory.
         ** Otherwise, if this is a 'save' operation (isSave==1), then data
         ** is copied from pInMemory to pFile.  Set the variables pFrom and
         ** pTo accordingly. */
        pFrom = (isSave ? pInMemory : pFile);
        pTo = (isSave ? pFile : pInMemory);
        /* Set up the backup procedure to copy from the "main" database of
         ** connection pFile to the main database of connection pInMemory.
         ** If something goes wrong, pBackup will be set to NULL and an error
         ** code and message left in connection pTo.
         ** If the backup object is successfully created, call backup_step()
         ** to copy data from pFile to pInMemory. Then call backup_finish()
         ** to release resources associated with the pBackup object.  If an
         ** error occurred, then an error code and message will be left in
         ** connection pTo. If no error occurred, then the error code belonging
         ** to pTo is set to SQLITE_OK.
        pBackup = sqlite3_backup_init(pTo, "main", pFrom, "main");
        if (pBackup) {
            (void) sqlite3_backup_step(pBackup, -1);
            (void) sqlite3_backup_finish(pBackup);
        rc = sqlite3_errcode(pTo);
    /* Close the database connection opened on database file zFilename
     ** and return the result of this function. */
    (void) sqlite3_close(pFile);
    return rc;
