Parts Needed
You will need below parts
20x 5 Watt SMT leds
1x Voltage step down Buck converter
I used a 3mm thich 8.5 inch aluminium utensil lid
thermal grease
Mains cable wires
toggle switch
20Volts 3Amps Laptop power supply
So first thing I did is clicked some macro photos and turned out really good.
Can also be used for vlogging, video making, potrait shots
The Rig turned out really nice however there are few things which I noticed which I would like to tell you.
Heating because the aluminum lid was thin so the Picture what you see above is the second version of it in which I used a thicker plate ( Instructables for the ring light ver2.0 will be uploaded really soon).
Please go though my youtube channel for more
Like share & subscribe
jugaad.it.yourself
Szabolcs Lőrincz
jackw01
James Cannan
maildodanillo
