1Make a Connection ON Breadboard
first make tight and proper connection as per circuit Diagram.For check the working Of 4026 ic i make a monostable counter for testing.
2Astable 7 segement counter
cascade connection of 4x 4026 with 4 x 7 segment display
3Cut the Project Box
using Female Header as Holder of 7 segment display
4cut the PCB Board
5Make a space for Battery
back side
Front Side
6Solder the PCB as per circuit Diagram
7assemble the circuit board in Box
add reset , stop and on/off switch
reset pin 15
stop pin 2
8Final
it Look Like This
9Working Video (Subscribe My channel)
Abhishek Tiwari
