Solder headers on the two contacts labeled TV and any +5V and GND. Attach the Pi NoIR camera using flex cable and power it up.
$ sudo raspi-config
Interfacing Options -> Camera -> Enable
Boot Options -> Desktop / CLI -> Console Autologin
$ sudo vi /boot/config.txt
add the following lines
framebuffer_width=320 framebuffer_height=240 sdtv_mode=0 sdtv_disable_colourburst=1
$ shutdown -h now
Power off, crimp Dupont connectors onto wires and plug into appropriate headers. Unplug HDMI.
Power on and the CRT glows.
![](https://cdn.hackaday.io/images/8399341548644827947.jpg)
No Dmesg output From Linux. Time to troubleshoot.
